Windstar O2 sensor replacement, which side bank 2? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 05-16-2005, 08:10 PM
Thornido's Avatar
Thornido Thornido is offline
Thornido is starting off with a positive reputation.
Since my Windstar isn't a truck I thought I'd ask in this forum. Which side is bank 2? I'm replacing an Heated Oxygen Sensor. I had the codes pulled, but I can't find which bank is 1 and which is 2. I finally found a Haynes Manual and it doesn't say. That is one hard to find manual. Anyway, hope it's a simple enough question.
2000 Ford Windstar 3.8L
Thanks
Old 05-16-2005, 10:19 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Bank 2 is the left or front bank on a BreakWindstar.
Old 05-17-2005, 07:45 AM
F150'89 F150'89 is offline
F150'89 is starting off with a positive reputation.
Bank one would be the side of the engine that the #1 cylinder is on, bank two would be the other side.
Old 05-17-2005, 01:07 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
This (should) goes without saying, but hope you have tested your sensor for proper operation before you toss one out because of a code.
The O2 sensor really only goes bad due to age and the crud that accumulates on it over time.
Basically, we don't care for you to pay for a sensor when giviing us the code to pick at may diagnose a bad fuel pump because the O2 isn't puckup up a high enough fuel mix from the exhaust....
Old 05-17-2005, 02:40 PM
Roushians's Avatar
Roushians Roushians is offline
Roushians is starting off with a positive reputation.
How do you easily connect your multi-meter to the O2 sensor for testing? The O2 sensor's power leads must be connected for testing, yet you need to tap into the wire to test it.
Old 05-17-2005, 04:12 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
When in doubt replace it. Chances are if it's setting a code it's shot anyway. These newer cars and truck are a lot better at diagnosing themselves than the older ones.
Old 05-19-2005, 02:40 PM
Thornido's Avatar
Thanks for all the info. I replaced the front ( left side since the engine is in there sideways), O2S, cleared the codes and and it's running real nice. Since another trouble code hasn't shown up yet, I figure I'm in the clear in that department until the other O2 sensors start going. I'll just replace 'em as they go out. Fortunately all four are pretty accessible. I haven't tossed the old O2S out yet, I figure i'll test it to make sure. First things last, I know Bass Ackwards.
Thanks.
O2 sensor bank one pnp522 Modular V8 (4.6L, 5.4L) 3 07-15-2015 05:40 PM
2003 windstar Cowboy_troy76 General Automotive Discussion 2 05-31-2015 03:29 AM
95 winstar 69issofine 3.8 & 4.2L V6 0 12-11-2014 02:36 AM
Keep getting 2 codes 03scf250 General Automotive Discussion 5 10-04-2009 07:58 PM
98 windstar problem bentwings General Automotive Discussion 4 04-17-2004 02:53 PM
Tags
03, 2, 2002, 2003, 2005, 38l, 98, bank, escape, ford, located, location, o2, sensor, windstar, winstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
