Is there a way to calculate speed change?
Old 05-16-2005, 08:51 AM
75Player's Avatar
75Player
75Player is offline
Can you calculate the difference in the speedometer reading after increasing your tire size? I just went from the stock STX 17" Continentals to 33's and am curious if there is a way to tell how far off my speedo is now (without a radar gun). Thanks.
Old 05-16-2005, 09:11 AM
64f10's Avatar
64f10
64f10 is offline
Question ... was the speedo correct before the tire change?
A GPS works great! Or you can estimate with:
Speedo & Tire Calculator
Old 05-16-2005, 09:23 AM
75Player's Avatar
75Player
75Player is offline
Yep, the speedo was correct before the change.
Thanks for that site. That answered my question.
Old 05-16-2005, 09:50 AM
dondon623's Avatar
dondon623
dondon623 is offline
I just had my wife drive next to me with windows down to tell me her speed or with our Nextel's.
Old 05-16-2005, 09:56 AM
osbornk's Avatar
osbornk
osbornk is offline
Try this:
http://cat.cc/tiresize.htm
Old 05-16-2005, 12:59 PM
Toreador's Avatar
Toreador
Toreador is offline
Go to Discount tire website and use their calculator.
Old 05-16-2005, 01:47 PM
Adrnlrsh's Avatar
Adrnlrsh
Adrnlrsh is offline
For a quick calculation, measure the circumference of the old tires vs the new tires as a percentage and use that number for the speedo correction factor. If the old tires measured 100" and the new tires are 110" then you would have a 10% correction factor so if the speedometer showed 60mph you would actually be going 66 with the bigger tires.
02GrayPowerStroke
10-08-2007 09:42 PM
Motorhead-42
15
05-14-2007 07:34 PM
73F100*8Mile
25
03-01-2006 11:54 AM
EgoMan
07-13-2005 07:43 AM
coglesby
03-31-2004 07:54 PM
Quick Reply: Is there a way to calculate speed change?
