super chips tuner and saggy transmission?
Aha! Good question. I noticed this on my truck as well. I am running a Diablo flip chip and when not in stock position, it seems real tight in first, then when it goes to second it's almost as if something lets go (gets kind of soft) and then gets solid once the T/C locks up. This DOESN'T happen when in stock tuning for me either.
It would sure be nice if the tranny would hold the 'solid feel' from first to second, cause it sure wants to pull!!!!! And no, my tranny isn't bad, got less than 5,000 km's since a rebuild. :-)
I had the same problem when I got my Diablo Sport tuner and would run on any other setting but stock. I took it to a Good tranny shop where the guy basically owns the same truck and let him tell me what he thought. He said that the sonnax valve would help it but the real fix would be a triple plate torque convertor, new high flow valve body, and new accumulator valves, shift kit, etc. So I had him just do it up right and have everything new in the whole thing and it only cost me around 2950 total. The way it shifts now and the difference that you can actually feel of the power on the ground is worth every penny spent, and I won't have to worry about replacing the tranny when I least expect it.
Originally Posted by voodoolord
Well my trans just puked out every drop of trans fluid about 5600 feet up the side of a mountain. I got it about 15 miles before it would not move. I had the wife meet me with some fluid and refilled it and it held till I got home. anyone have any idea what happened this time?
Warren
I was just cruising up a windy mountain road. I got to a slightly steep part and put in 4wd for just about 200 yards and parked the truck. I got out and it was like a cow pissing on a flat rock. I just jumped straight back in the truck and tried to get as close to civilization as I could. The first time that I noticed I might have a trans problem was last week on the same road I got stuck in some snow and was working the trans backward and foreward trying to get out, I saw it dripping a little then. Its coming out of the weep hole under the bell housing. That help?
No fluid means no line pressures means problems if you keep going. Back to the start, if the seal got toasted, it could be due to two primary things (or others), one, the tranny got REAL hot at one point and baked, or two something else is letting go in the tranny giving off metal particles which chewed the seal.
It's a bitch to do, you basically have to drop the tranny to get the t/c off, then pull the seal and relace with a new one. It's kind of funny because the seals are dirt cheap and it takes only a few minutes to replace the actual seal, the real bitch is the r and r on the tranny.
Anybody correct me on this incase I am off base?
on another note im looking at bidding on these sonnax parts for the tranny but im not sure if they are the same thing. Can anyone tell me whether their the same or not?
http://http://cgi.ebay.com/ebaymotor...MEWA%3AIT&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
and should I put this in the tranny while its out?
