1996 ford explorer fuel shut off switch - Ford Truck Enthusiasts Forums
Old 05-14-2005, 04:39 AM
larsonyst1 larsonyst1 is offline
larsonyst1 is starting off with a positive reputation.
hello i have a 1996 ford explorer and i can not find the emergency fuel shut off switch.could somebody please tell me where this switch is located.thanks
Old 05-14-2005, 06:23 AM
fitter565's Avatar
fitter565 fitter565 is offline
fitter565 is starting off with a positive reputation.
It should be on the front passenger side, above the kick panel. Your manual should be more specific.
Fitter
Old 05-14-2005, 09:43 AM
1996 for explorer
hello thanks for the input i will check there as soon as i get a free minute thanks again.
Old 05-15-2005, 08:53 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Also, make sure that the plug on the bottom of it is on tight.
fuel reset switch Glenn Blackwell Explorer, Sport Trac, Mountaineer & Aviator 5 08-06-2014 06:15 AM
Security Shut off Switch? redbug 1999 - 2003 7.3L Power Stroke Diesel 5 05-15-2014 08:06 PM
inertia fuel shut-off switch tunker Explorer, Sport Trac, Mountaineer & Aviator 4 12-22-2008 02:10 PM
HELP! need location of fuel pump reset button Tyger9791 Explorer, Sport Trac, Mountaineer & Aviator 3 05-17-2002 10:18 AM
changing fuel filter on 97 explorer briski04 Explorer, Sport Trac, Mountaineer & Aviator 6 04-04-2002 08:06 AM
Tags
1996, 96, bottom, cutoff, emergency, explorer, exployer, ford, fuel, location, shot, shut, shutoof, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
