Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-13-2005, 09:07 PM
TheFrog TheFrog is offline
Garage is empty, add now
TheFrog is starting off with a positive reputation.
Engine Designs
Here is the new thread I promised,
What about a different non-metallic substance for making piston rings?
Any other ideas about reducing friction or increasing efficiency in an engine?
  #2 (permalink)
Old 05-15-2005, 06:41 AM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
Teflon coated piston walls I believe have been done (Honda maybe???) to reduce friction.
Using High strength aluminium alloys instead of steel for rotating parts would reduce rotating weight.
New bearing designs. The hydramatic bearings used currently are fantastic for holding huge loads while taking up little space, but they aren't the most efficient.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #3 (permalink)
Old 05-22-2005, 02:46 PM
bodabdan's Avatar
bodabdan bodabdan is offline
2003 Ford F-350
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
Sorry I can't elaborate in detail on these items but I have heard of a few things.
Replace bushings and traditional style engine bearings with roller bearings.
Full roller valvetrain.
Eliminate valvetrain all together by using electric solenoid operated valves.
Hollow cams and cranks.
Hypereutectic pistons and coated piston skirts
Variable valvetrain timing.
"looser" machining tolerances.
__________________
2003 F-350 for sale-http://www.ford-trucks.com/forums/12...l#post12446411
97 F-250 PSD, 2012 F-350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
