Propane Info setup
Old 05-25-2005, 11:28 AM
thesprocket26's Avatar
thesprocket26
thesprocket26 is offline
Propane Info setup
Hey ya'lls. I have a Impco 425 carb and two other thingys. One of them flows water and gas through it and the other has a VFF30 number cast on the top side. What are these things? Is there some diagrams or instructions for installing propane I could get? Also, what kind of fuel lines/hoses do I need to buy? Do they have to be special? I'm building a propane 400 motor for my 67 f100 4x4. Thanks.
Old 05-25-2005, 12:40 PM
351M's Avatar
351M
351M is offline
Go to www.propaneguy.com, it sounds like you have the main 3 components though. 425 is the mixer, the part that flows water through it is the regulator or vapourizer, what ever you want to call it, and the other should be the lockoff valve (fuel shutoff) This will all have to be certified before you can fill it as well.
blueeyedfordguy
88
03-13-2010 01:53 PM
fishindave11
04-22-2007 10:34 AM
turboman24
03-05-2007 06:28 PM
superduty4x4
04-19-2006 07:36 PM
bcford6.9
29
04-06-2006 08:55 AM
Quick Reply: Propane Info setup
