Camber kit for 2000 Ranger 2WD, 3.0L
My upper ball joints are also bad on the Ranger, so I ordered two Moog upper control arms from rockauto. They should be here next week.
I see in the parts listing an entry for a caster/camber kit for each side. Looks like bolts with cams and some washers and nuts that go where the control arm mounts to the frame. Is this something that has to be replaced when the upper control arms are replaced so it can be aligned or are they not needed?
Thanks Dave. I took a closer look today after I got home. One side looks like a cam of some sort and the other side has a rectagular plate that looks like it locks down the camber so it cannot be adjusted. The kit you can buy has the cam on both sides. I guess that what I was reading about needing the kit
Originally Posted by greenpus
there is no reason to replace them unless you install a lift kit. They don't wear out.
Dave
Originally Posted by Dave257
It can easly be out of alingnment after replacing frontend parts. As I said the factory alignment is set with a standard square washer, Dave
I installed the kit on my 2000 because of a lift I installed and it pretty much looked like a square washer to me
pancake
08-18-2010 02:53 PM
scacho
03-17-2007 05:09 PM
