F-100 Transmission - Ford Truck Enthusiasts Forums
F-100 Transmission
Old 04-15-2000, 12:11 PM
Raul Raul is offline
Raul is starting off with a positive reputation.
F-100 Transmission
Shhh. Be vewy, vewy quiet; my wife thinks I'm up here working on our taxes.:-)
I have an 81 F-100 w/ 4-speed overdive. VIN indicates this is Clark-4 speed OD. The driver's side of the trans is stamped: Ford RF-D9BR-7006-AB
C-2604194. Ford dealer says that is number for Ford 4-speed Overdrive. Passenger side of trans has tag with following: RUG DT LA22 EITR CB 1989.
Are Ford 4-speed OD and Clark 4-speed OD the same thing?
Here's more confusion: the trans code chart in my chiltons (pg 1-9) lists a clark 4-speed OD (Ford 4-speed OD is not even listed for any year) but on page 7-3 it mentions a Ford RUG 4-speed OD, never discusses clark 4-speed. Things that make you go Hmmmmm?
Am I reading too much into this and the transmissions are the same? If I want to buy an overhaul kit, what do I buy - er, for which transmission?
I know some of you guys know the answer - and I appreciate your time and help.
Back to the 1040 - yeah, right!
Thx
Raul
Old 04-18-2000, 09:39 AM
BillW BillW is offline
BillW is starting off with a positive reputation.
F-100 Transmission
I can't swear to it but I think they must be the same. My 1980 VIN indicated a Clark, but casting is marked Ford and I have the same type of numbers you indicate. Likely build by Clark for Ford. I know my Carb has lettering on it indicating that it was manufactured by Carter for Motorcraft. Likely same type of thing.
BillW
1980 F100 Custom Shortbed
300 I6 w/4spdOD Manual
(105,000 miles)
Old 04-18-2000, 06:27 PM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
F-100 Transmission
Clark 285 transmission JERSEYJOE2937 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-21-2016 12:12 AM
Another Clark ID Thread F250racer Large Truck 3 02-12-2015 06:56 PM
5 speed Clark & New Process transmission identification 38 coupe 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 12-15-2014 03:51 PM
Anybody with a T19 trans on a 300 six-inline? superbepro Ford Inline Six, 200, 250, 4.9L / 300 44 10-29-2013 08:11 PM
5 speed Overdrive Clark sampine336 Clutch, Transmission, Differential, Axle & Transfer Case 1 05-15-2002 10:42 PM
Tags
4speed, c2604194, clark, ford, id, manual, od, speed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
