Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-12-2005, 12:29 AM
Greywolf's Avatar
Greywolf Greywolf is online now
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
(hypothesis) Begin at the wheels...
Wheels are the major 'unsprung weight' load on any vehicle. But they are also highly 'energy absorptive', and there are a number of theories as to how to reduce loading on a drivetrain by cutting the load right at the hubcaps. Any bicyclist knows well the difference between pumping big tires, and running on small diameter high pressure tires (road and touring bikes). The principle does not change just because we are looking at a truck instead of a bicycle - if anything, it brings to us a test sled on which to chase the idea even further...
We should explore this, especially now. What we learn and save could go right into the BANK!
The dynamics of a rotating tire are not what most people think they are. As a tire/wheel rotates, ALL of the mass it is made up of is constantly changing direction - and that requires an energy expenditure. THEREFORE reducing the total mass reduces the amount of energy required in order to just turn the wheel. This energy expenditure increases directly in proportion to increased RPM at the axles.
Bottom line here is that BIG tires should be reserved for slow going and off road use. For the highway - normal width, moderate sidewall, high pressure ('E' rated tires are pressurised to 80 PSI) tires on alloy rims are the best way to go.
NOTE: Taller wheels/tires have a lower overall rotation rate for a given speed of travel in miles/kilometers per hour.
-Comments?
__________________
"It's about doing what's right, not about being "tough". Unless you find it tough to do what's right, I guess..."
~NewEnglandHerdsman
Last edited by Greywolf; 05-12-2005 at 12:41 AM. Reason: Further clarification (definition)
  #2 (permalink)
Old 05-12-2005, 02:59 AM
There Goes The Neighborhood's Avatar
There Goes The Neighborhood There Goes The Neighborhood is offline
Garage is empty, add now
There Goes The Neighborhood is starting off with a positive reputation.
Removing 10 lbs of rotating weight is the same as removing 100 lbs of dead weight. To feel a measurable difference in mileage, it takes 500 lbs of dead weight (or 50 rotating) removal to gain 1 MPG.
Not only would fuel mileage increase, but there would be less wear and tear on components, such as shocks, wheel bearings, brakes, etc. The vehicle would accelerate faster, stop shorter, handle better........ You get the picture.
Reducing rotating weight is a good start, but, it's proven that though the higher load range tires offer reduced rolling resistance, the increased weight of the tire negates any possible benefit in that department. If you were to develop a lightweight, low rolling resistance tire, with a moderate sidewall height, it, IMO, would not be fit for installation on any vehicle that hauls any amount of weight.
__________________
Brandon
'02 Dodge Durango
"The voices in my head may not be real, but they have some good ideas!"
  #3 (permalink)
Old 05-12-2005, 10:18 AM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
A tire company has re-invented the wheel recently. The wheel is plastic and is very light, the tires are non inflatable, the wheels structure produces the shock absorption. They will probably only be on small, light cars to start but maybe they will be able to make them strong enough for trucks. They debuted the wheels at one of the major car shows this year.
Also, magnesium wheels are much lighter than aluminum or steel wheels. A 45# aluminum wheel would weigh 30# made out of magnesium.
  #4 (permalink)
Old 05-15-2005, 06:38 AM
BigF350 BigF350 is online now
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
Magnesium wheels are a start, and using more exotic materials in the drivetrain would help a LOT.
Increasing efficiency in the gearbox and differential would assist significantly.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #5 (permalink)
Old 05-22-2005, 02:52 PM
bodabdan's Avatar
bodabdan bodabdan is offline
2003 Ford F-350
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
The fastest vehicles at Bonneville are probably using very efficient designs. Suitability for cornering, ride comfort, and wear, well that's a different story.
__________________
2003 F-350 for sale-http://www.ford-trucks.com/forums/12...l#post12446411
97 F-250 PSD, 2012 F-350
  #6 (permalink)
Old 05-29-2005, 01:35 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
http://www.michelinman.com/differenc...01102005a.html
wouldn't these be great in truck sizes...imagine the weight savings...
__________________
Hey Guys.....vote for me please...
http://www.ford-trucks.com/forums/97...round-7-a.html
  #7 (permalink)
Old 05-29-2005, 08:10 PM
furball69's Avatar
Those are the ones I was referring to but I couldn't remember the company.
  #8 (permalink)
Old 05-29-2005, 08:42 PM
Ryan50hrl's Avatar
those things just look cool...i'd buy them for the cool factor if nothing else
__________________
  #9 (permalink)
Old 05-29-2005, 09:40 PM
2000 Ford F-350
My Garage
That is very cool indeed.
I wonder about the weight carrying capacity however.
It is ironic though...
We are going from flexible ferrous based suspension devices to pneumatic based suspension, and we are going from pneumatic tires to flexible ferrous based tires...
__________________
  #10 (permalink)
Old 06-06-2005, 06:42 PM
bdjupiter's Avatar
bdjupiter bdjupiter is offline
bdjupiter is starting off with a positive reputation.
If you look through the pictures it shows them on a Cat front loader, so I guess weight carrying capacity wouldn't be an issue. It kind of weirds me out to see a car going down the road with those things on though.
__________________
2000 5.4L F-250 SC 4X4
Diablo Chip
Gibson Exhaust
K&N Stage II
Wheels & Tires
  #11 (permalink)
Old 06-07-2005, 08:04 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is online now
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
ah yes, i think that they called them tweels in four wheeler or four wheel and off road.
so with two otherwise identical tires, one rated at 50 psi and one rated at 80psi, the one that takes 80 will get better mileage?
and does that also mean that 235/85's would do better than my 33/12.50's even though they are a big shorter (taller tires make the engine turn slower at any given speed)
also i have heard that over 40,45 mph air resistance is a bigger factor than rollng resistance.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #12 (permalink)
Old 06-07-2005, 08:15 PM
2000 Ford F-350
My Garage
Yup, but for city cars, that still means rolling resistance is a big thing...
  #13 (permalink)
Old 06-07-2005, 09:26 PM
jbau jbau is offline
jbau is starting off with a positive reputation.
Intriguing topic... I'm of a mindset now to do anything (within reason) that I can to improve the efficiency of my vehicles. So, is it worth investing in lightweight wheels? Which ones have the load-bearing capacity needed for a truck?
  #14 (permalink)
Old 06-11-2005, 09:52 PM
Dino@his Dad's Dino@his Dad's is offline
Dino@his Dad's is gaining momentum as a positive member of FTE.
well, yeah
Wolfus, I like your thinking on this. I don't know for certain about aluminium or magnesium wheels, however. Lots of the alloy wheels are heavier than steel ones. I would have to imagine this is because most of the alloy wheels seem to be designed for looks, rather than weight savings. But a carefully designed alloy wheel might be just the thing. Doesn't Alcoa make something we might could use ? I really like the high pressure tire idea. I went and looked at the wheels and tires on the UPS truck that comes every day to my shop. It had 9x19.5 tires on it. They were load range E, and were about 37 inches tall, with about a 6 inch wide tread face. If one could find some 19.5 wheels with a bolt pattern to fit our trucks, that might be a neat size to try. DF, @ his Dad's house
  #15 (permalink)
Old 06-21-2005, 03:41 PM
Greywolf's Avatar
WILD CARD
1989 Ford Ranger
There was a time when Budd rims (for semi's) were illegal in the state of California. Trucker liked them as much for the looks and name as they did for the weight and rolling resistance savings. These days - there are a lot of big rigs with alloy rims, and there is good reason for it.
For a pure, solid enough to handle speed/load, straight-up road rim I would think centerline or some similar manufacturer ought to be ideal. Western is long out of business, but they were said to have some of the best engineered rims around. Budd may still be out there - I'll surf around and see in a minute.
Looks don't equal MPG, and in fact can reduce it a lot. The reason for cut-outs in early rim designs was to aid in cooling brake discs and drums on racing machines. There are better ways to do that though - Air-Dams on front ends had ports at the outer ends to duct cold air directly to the brakes using 2" - 3" flexible hose, many race cars still use this method today. Lighter duty vehicles ought to have no problem with a non-ventilated rim design or even "MOON" hubcaps. (Which I always thought were cool anyway)
There are dual-metal rims designed for show that are intriguing. A hardened steel hub area with a larger alloy circumferance composition might be a possibility (my thought). Corrosion would be the main drawback, because of dissimilar metals in the design.
Mainly I have thought that some of the "Joe Cool" 21" rims might be a good idea if they were solid center designs instead of being "Fancied Up" with alien looking spoke designs. Picture a 21" centerline racing rim with a narrow or modest sidewall...
~Wolf
__________________
~NewEnglandHerdsman
Tags
1973, f250, steel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
