Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 05-11-2005, 11:02 AM
fordlvr25 fordlvr25 is offline
Garage is empty, add now
fordlvr25 is starting off with a positive reputation.
99 ranger whining/whistling noise
anyone else this problem, driving along and you can hear a high pitched whining noise, sounds like it is coming from the drivetrain.
Thanks
  #2 (permalink)
Old 05-11-2005, 03:45 PM
Rockledge's Avatar
Rockledge Rockledge is online now
Rockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to all
I've heard of the PVH hubs making a whistling sound when they haven't been used in a while, even in 2WD.
Do you have 4WD? If so, next rainstorm be sure to engage the 4x4 system and drive around for a little, see if that helps with the noise.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 05-12-2005, 07:21 AM
Phitty Phitty is offline
Phitty is starting off with a positive reputation.
I have a 2000 B4000 with the PVH Hubs.
My truck does the same thing - especially in the spring and fall, and never in the winter (when i use my 4x4 more often). I think it may also be related to moisture/humidity levels but thats just a theory. Im not sure what the sound is but I think its a rubber squealing sound from a dry seal or something.
Turn on your 4x4 and listen to see if the noise decreases or goes away entirely. Its not a permanent fix but makes a difference for a day or two.
If I use 4x4 alot then the whining goes away for a longer time.
Hope that helps a little. If you find a better solution make sure to let use know.
P.
  #4 (permalink)
Old 05-12-2005, 08:08 AM
Whining noise
So as of right now there is no fix for it. it is just so annoying when you are driving next to someone and you can hear it. but we have concluded that it is probably with the 4wheel drive system, can you grease or lubricate anything up there so it wont do that...
Tags
1997, 1999, 2000, 2002, 40, driving, ford, intake, making, noise, ranger, sound, whine, whining, whinning, whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
