dual exhaust on 55 f100 w/yblock
yOU CAN USE THE EXISTING MANIFOLDS AND HAVE AN EXHAUST SHOP CUSTOM BEND A PIPE OUT OF THE FRONT LEFT MANIFOLD AND RUN IT DOWN. Also if you find a passenger car right manifold and install it on the left side the outlet will be in front. A Pass. side manifold from a car will fit on the pass side of a truck but the drivers side will not clear the steering box.
If you do either of these two ways you need to remove the fuel pump, install a cover plate and install an electric pump at a different location as the orignal pump may get too much heat with the exhaust so close.
Kevin Bigwin
Kevin Bigwin
fabieber
01-21-2014 07:05 AM
Fomoko1
80
04-13-2008 02:39 PM
