Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-10-2005, 11:31 PM
bdraft bdraft is offline
Garage is empty, add now
bdraft is starting off with a positive reputation.
carbs on the 4s
Q: I was thinking it's either just the gas being bad or a cloged jet in the carb, what do you guys think? Something else?
background info below:
I have an old '84 Ranger with the 2.3L OHC in it. It had a rebult 1bbl installed on it a few years ago and then the truck sat for about 4 or 5 years after that, starting it very infrequently. Now the engine won't start unless you squirt carb-&-choke cleaner into the intake (poor-boy's starting fluid) if it hasn't been running in the past 5 minutes or so.
The engine idles smoothly and has good power, so I don't think I'm getting a vacum leak. I am un-able to drop the tank and drain it on the truck, so I dumped a bottle of STP fuel treatment, a bottle of Heat, and a half a can of B-12 ChemTool in the tank and topped off with about 6 gallons of premium unleaded.
Oh, no, I haven't changed the fuel filter yet, was going to wait till I burned that tank of fuel out before I put a new filter on it.
thank you for your time;
bd
  #2 (permalink)
Old 05-18-2005, 10:07 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
I would change the filter, cheap and easy.
I am also willing to bet on a worn out fuel pump, electric or mech?
It could also be a worn out accelerator pump, look down the carb and pup it a couple of times and it should squert some fuel down the hole.
__________________
82 Bronco 351w C6
95 f-150 300I6 5spd 2wd
My truck likes mud.
  #3 (permalink)
Old 07-05-2005, 11:26 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
acc pump.... maybe even a choke
__________________
RIP all my fords.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
