1981 4x2 and 4x4 9" axel code help
hey everyone, can some one give me a hand here??? I have a 1981 f 150, with a I6 300, with a door jam axle code of H3, what ratio is it??
Also, 1981 f 150, with 302, anxle code H22, what ratio is that??
Any help will be greatly appreatated
Thanks
P.S. I look for 2 hours, and came up with nothing and the ford shop in town cant tell me either
Thanks
for the 1981 300 6cyl I found H3 is a limited slip 4.11 gear ratio On the 1981 302.It could be a misprint on the door sticker. I can find a 1980 code H2 as a 3.50 Ford 9 inch. I show code 22 only in an 8.8 inch rear 1983 and newer and a 4.10 ratio. You probably have a 9 inch, so more then likely you have the 3.50 rear. Can you get the info of the rear end of the 1981 302 we would be able to confirm what it is.
JPalmer81
105
06-25-2015 12:46 PM
FixinOlBlackie
11-08-2013 02:11 PM
chad420
03-17-2009 03:53 PM
Trevor1
06-17-2007 07:41 PM
bcboy4ca
03-26-2005 03:09 PM
