Vibration and wind buffeting
I'm sure anyone who has the Screw has noticed how bad the buffeting and windnoise is if you roll down the back windows only.
This morning while washing my truck, I noticed that if you look under the rear wheel wells, there are 2 holes in the frame. One is round, and one is square. You can see all the way through to the other side.
Is it possible that wind going through these holes is causing the vibrations at certain speeds?
I dont think so. The pressure gradient below the bed is much different than the rushing air past the windows, and the cab pressure. The buffeting is due to the fact that the pressures cannot equalize. With those rear holes, the air equalizes very quickly because there isnt a 'pocket' maintaining the pressure (like the front of the cab).
canoe86
90
09-17-2019 12:13 AM
PJJTLC
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
12-05-2016 11:25 PM
FiveOJester
1999 to 2016 Super Duty
06-14-2015 10:31 PM
