1988 F 350 fuel problem
I have a 1988 ford F 350 with a 460. It's not getting fuel. If you spray it with ether it runs on the ether and then stalls. It was towed in last year for the same problem and I had changed the relays and it was running, but now it won't run again. The fuel pumps, all of them, were replaced last year. Any ideas on what to look for? Thanks.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Fuel pumps
Did you ever get a reply concerning your fuel problem? I have a 1989 F250, 4x4, 351, 5 sp with the same problem. All was well one minute and then the truck just stalled out. Engine cranks but doesn't turn over. I changed the relay in the engine compartment with no change. I don't hear the pumps prime when I turn the ignition switch on. Did you have any luck?
dutch250
89 F250 4x4 351 5 sp
dutch250
EKlev
04-26-2015 07:52 AM
sek
08-02-2010 09:37 AM
