Can't Wait.....
Can't Wait.....
Just got some work done on the Bronco this past week...
engine flush
Oil change
fuel filter
PCV valve (really needed)
and some small fixing
I had some major oil foaming going on and lots of leaks so I thought that there was really bad blow by and in need for a major rebuild. Well when I changed the PCV there went my foaming and I put in really thin oil (5w30) and a can of restore now I just have to drain the oil soon and put in something thicker, prob 15w40 or something like that. I have some new wires and plugs, cap and rotor to put on.
Now for the really really good part............
I did some stereo work for a local preformance/tire shop here in town and I got a really good deal for a stock size 2bbl Holly carb that I need to put on the Bronco...................
Just had to let you guys in on the good news
engine flush
Oil change
fuel filter
Beast I have been debating the SAS for a whyle, I have done some major research on it and come to find out that is you will loose alot of ride comfort and with all the travelling with camping, I think that is something I just might keep for a all time off-roader, and just do a small lift and buy bigger tires for this one.
Thanx for the tip Deal I might try the 10w40, I do alot of travelling and I want to protect this motor as long as I can. I have another block to build up but no$$$$$$ to do it with..
J. E. C.
07-30-2016 02:32 PM
BigBlkEX
09-11-2014 03:35 PM
