Wet Spark Plug - Ford Truck Enthusiasts Forums
Wet Spark Plug
Old 05-24-2000, 10:13 PM
Guy Guy is offline
Guy is starting off with a positive reputation.
Wet Spark Plug
I was wondering what kind of problems are usually associated with wet plugs. I removed them today to check the gap and found one wet with what I think was fuel. Not dripping wet but definitely damp. All the rest were dry and clean. The one that is wet is the one on the right hand side nearest the firewall standing in front of the engine(truck)looking in. I noticed this last week while doing a compression test but the pressure of that cylinder was ok. For this plug to be wet both times I removed it can not be a coincidence can it?
'92 F150 XL 4x4, 5.0L AOD, Headers, K&N Air Filter, 3.55 Gears, 31x10.5x15 Tires.
Old 05-24-2000, 10:42 PM
Torky Torky is offline
Torky is starting off with a positive reputation.
Wet Spark Plug
Sounds like an ignition problem. No spark in that cylinder equals wet plug. Check plug wire, distributor cap. BTW, rear cylinder on driver's side is number 8. Cylinder number 1 is front on pass. side.
Old 05-24-2000, 10:46 PM
CJay CJay is offline
CJay is starting off with a positive reputation.
Wet Spark Plug
It sounds like that cylinder is not firing.Check the cap wire and plug one of them is probably bad.
Good luck.
Old 05-24-2000, 11:19 PM
Guy Guy is offline
Wet Spark Plug
Well I pulled the wire off while the engine was running and noticed the idling drop a little and I also saw a bright spark arcking across the plug and wire boot. Any other suggestions?
Old 05-25-2000, 01:53 PM
jmerritt jmerritt is offline
jmerritt is starting off with a positive reputation.
Wet Spark Plug
2000 f-350/ cab over ? Mickey Bitsko 1999 - 2003 7.3L Power Stroke Diesel 11 03-13-2016 09:44 PM
Engine evaluation... results, opinons? Nyquil Junkie Ranger & B-Series 11 02-18-2016 08:42 AM
Battery Drain when wet kbarbee95 1999 - 2003 7.3L Power Stroke Diesel 4 02-04-2015 02:33 PM
Wet Spark Plug? Zach Mahnesmith Modular V8 (4.6L, 5.4L) 4 12-15-2014 08:10 AM
Water in spark plug well, cyl.#4 weevensteven Modular V10 (6.8l) 3 04-28-2014 01:24 AM
Tags
cylinder, f150, ford, plug, plugs, spark, wet, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
