PCM Power Relay - Ford Truck Enthusiasts Forums
PCM Power Relay
Old 05-05-2005, 11:10 AM
mtntop1's Avatar
mtntop1 mtntop1 is offline
mtntop1 is starting off with a positive reputation.
PCM Power Relay
Does anyone know where the pcm power relay is located is it in the engine compartment fuse box,also I keep blowing the 20amp fuse in the engine compartment fuse box that goes to the pcm power relay as soon as I turn on the ignition switch without turning the engine over. It's a 1995 F-150
Old 05-06-2005, 07:34 AM
95X15 95X15 is offline
95X15 is starting off with a positive reputation.
PCM power relay is the bottom right hand relay, fuel pump relay is above it. Fuse I feeds PCM relay and goes to a splice in the engine compartment that feeds all the sensors that control the PCM outouts - wire #361 red; Any short in this lead will blow fuse as will a burnt up relay. Pull the relay first and see if fuse blows if not put the relay back and disconnect PCM 60 pin connector at driver's side fender well below brake cyl/booster. make sure battery is disconnected while dicconnecting/connecting 60 pin connector to prevent damage to PCM and be sure the connector is moved far enough away from PCM to be sure it wont get pushed up and make contact while you try the power to the relays; there are also several feeds to the PCM thru the relay, only pin 1 goes straight to the PCM off Fuse I. Hope this helps - info from 95 elec/vacuum manual.
Old 05-06-2005, 08:20 AM
mtntop1's Avatar
Found The Short
I traced the short to one of the wires in the Transmission ,It seem that when I changed the trans fluild a few months back I pinched a wire behind the filter.Looking at the wiring diagram power goes to the PCM relay and then branches of to the #1 and elect press control sol in the trans.So I dropped the pan and took out the filter and to my suprise the wire was pinched and the insulation was broken.Fixed the wire and put everything back together and the problem was gone.Thanks 95X15 for your input.
Old 05-06-2005, 10:18 PM
Glad you found the prob - did you just start having the prob after the filter change or did it take a while to show up? I wouldn't have suspected the transmission wiring to start with, did the wiring just get in the way when the filter went up? I'll watch thet a lot closer in the future. Thanks.
Old 05-06-2005, 10:45 PM
mtntop1's Avatar
To 95X15
It happened a few months after I changed the trans fluild.When I put the new filter in and it push one of the wires up behind it and pinched it.I guess over time with any vibration the insulation on the wire separated just enough at the pinch point that it shorted out againist the trans or filter.As for suspecting the trans wires it showed in the elect.diagram that when the igintion switch is turn on that power from the pcm relay goes to a central piont and then branches off in five dierctions,two of whitch go to the trans so I started there first remebering that I had the pan down a few months before and got lucking.I'll be more careful in the future.
96 F-250 HEAVY DUTY - keeps cutting off and blowing pcm fuse CRAZYC123 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2011 10:02 PM
Fuel Pump Relay: 2001 F250 V10 buckweber6 1999 to 2016 Super Duty 6 12-13-2010 09:25 PM
Wide Open Throttle Relay WOT stirfrysteve Ranger & B-Series 1 12-05-2010 07:26 AM
EEC Power Diode pchristman Electrical Systems/Wiring 5 02-22-2006 10:47 AM
1998 Ford F150 "won't start" aplummer 1997 - 2003 F150 11 08-07-2005 07:11 AM
Tags
2004, 99, battery, blowing, f150, f350, ford, fuse, gmc, location, pcm, power, problem, relay, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
