Oil pressure gauge doen't work when cold
Old 05-05-2005, 06:06 AM
penn's Avatar
penn
penn is offline
On our 2001 Explorer the oil pressure switch doesn't work when the engine is firts started cold.
After a few hundred yards it works and keeps working 'till the next morning.
Is it possibly a sticky oil pressure switch, or should I look for it in the wiring/electronics?
By the way, took a quick look but have not located the oil pressure switch yet, where is it located?
Paul
1972 F100 Ranger XLT
2001 Explorer Limited 4.0 SOHC
Old 05-05-2005, 04:43 PM
marragtop's Avatar
marragtop
marragtop is offline
My 95 does the same thing. Try smacking the dash board, and if jumps right up, then you know it's not really a pressure problem. Not sure about the 01s. Which motor do you have?
Old 05-05-2005, 04:44 PM
rekab's Avatar
rekab
rekab is offline
My 2000 did the same. I replaced the sending unit to fix it. In my 5.0 it was located above the oil filter.
Old 05-05-2005, 04:45 PM
rekab's Avatar
rekab
rekab is offline
oil filter
Old 05-06-2005, 11:56 AM
Foxfire1's Avatar
Foxfire1
Foxfire1 is offline
Oil Pressure doesn't work when cold
I have an '00 w/the SOHC V-6 for my work truck and it does the same thing, cold weather only. Once I realized it was just the gauge, I quit worrying about it! It now has 93k on it & has otherwise been a pretty good truck.
Old 05-19-2005, 11:54 AM
jcurrie's Avatar
jcurrie
jcurrie is offline
It's a common problem with the sending unit. It's not the guage.
Old 05-20-2005, 12:30 PM
gjmcclain's Avatar
gjmcclain
gjmcclain is offline
Does anyone know if the oil pressure gauge really indicates oil pressure? I know some gauges are basically an idiot gauge - they just indicate whether something is "on or off". Does this gauge just show that some oil pressure is present, or will it move up and down when oil pressure varies? The reason I ask is my gauge never moves once the engine is started, so I figured it was just telling me that it detected some amount of pressure.
Old 05-20-2005, 04:13 PM
marragtop's Avatar
marragtop
I'm not sure about the late models, but I believe the early models (91-95) were basically idiot lights in that they were either registering or not. I'm sure someone on this board will know how much pressure it took to make them register.
Old 05-20-2005, 10:34 PM
jcurrie's Avatar
jcurrie
jcurrie is offline
Mine is a 99 explorer sport and the "gauge" works like an idiot light. I don't remember how much pressure it takes buy it isn't much. Some where on this site there is a tech article that explains how to convert the gauge to a actual pressure working gauge. I can't remember how that is done either but it isn't hard to do other than taking off your dash panel and using a soldering gun. Hope this helps.
Old 08-04-2005, 02:49 PM
REOAZ's Avatar
REOAZ
REOAZ is offline
Also has a 2001 Explorer 4.0 SOHC with cold oill pressure light. I purchased a new oil pressure sending unit and have teh Ford Shop Manuals. Cannot find the unit to replace. Not by the oil filter on mine. the manual states on the left front of the engine. I see two sending units on the top front of the engine. The one on the left facing the engine is the temperature sending unit the one to the right of it might be the oil sending unit, but not sure and I haven't taken the time to remove the plastic throttle cover to pull it to see. Does anyone know for sure?
Old 08-05-2005, 01:28 AM
Jharger's Avatar
Jharger
Jharger is offline
Intersting question on oil pressure guages. Min I think is real - it moves up and down with RPM and cold/hot engine. Some say otherwise for fords.
Here is an article http://www.rebuilt-auto-engines.com/...53105598019.1e
here is a string on discussion https://www.ford-trucks.com/forums/s...t=oil+pressure
Old 08-06-2005, 10:07 AM
penn's Avatar
penn
penn is offline
Just replaced mine, it's a pain to reach. I managed with a socket wrench and a 15" extension. From the left front wheelarch I could put it straight through the innerfender and it perfectly lined up with the oil pressure switch. Took me about half an hour to figure it out, but when I did it was done in less then 10 minutes.
tip: some oil is coming out when you pull the old one, so loosen it till it can be turned by hand, and place the new one in the socket (which is still in place through the innerfender), then when the old switch falls out, you can immediately screw in the new one.
Paul
bismic
03-18-2017 08:30 PM
SoNic67
23
11-17-2010 03:51 PM
khadma
Oil & Lubrication
02-24-2008 09:27 PM
Snaderi
04-13-2004 10:19 AM
ledbetter
11-06-2003 01:48 PM
Quick Reply: Oil pressure gauge doen't work when cold
