Transfer case swap
if you plan on lifting the truck, stick with the divorced case, it is a really good setup, the drawbacks to the married case in a highboy is the front driveshaft will have a serious angle problem unless you have a high pinion frontend and not much lift because i think the engine sits higher in the frame (that will open a can of worms in this forum) and when you put the bolt up case in you need to keep the same tilted back angle on the engine which tilts the front output way up, besides the case you are wanting to put in is i think a 1356, aluminum, they wear, they break , they leak(so does a 205, but you can run muddy water in them and not hurt them)
51MHF5
05-28-2013 06:15 PM
714x4
07-27-2010 03:09 PM
SilverHighboy
07-12-2010 10:39 AM
$Simpleman76
04-14-2007 11:50 PM
