another newb needs help with codes
ok so i just pulled my error codes i looked on the fuelinjectio.com sitebut i dont now how to deficer the code so if someone can help that would be great
here we go
3-3-1 those were with long pauses 3 2 7 3 3 2 6 2 8 6 3 4 then it repeats it self 3 2 7 3 3 2 6 2 8 6 3 4
here we go
327 - DPFE or EVP circuit below minimum voltage of 0.2 volts.
332 - EGR valve opening not detected.
628 - Converter clutch Lock-up error (E4OD)
624 - Electronic Pressure Control solenoid or driver circuit failure
I believe your '33' code is actually a '1-1-1' pause '1-1-1' code, which is an 'all clear'.
As far as what these codes mean, I am unsure. I hope someone else can help you.
Ryan
Ryan
cessnapilot
15
02-27-2010 10:01 PM
swtsolutions
1997-2006 Expedition & Navigator
02-25-2007 06:36 PM
GRKSTL2
03-04-2004 04:06 PM
