F250 Dash light bulb replacement - Ford Truck Enthusiasts Forums
Old 05-03-2005, 03:24 PM
Poohperman Poohperman is offline
Poohperman is starting off with a positive reputation.
I have a 2001 F250 Crew Cab with Powerstroke. The dash lights are starting to go out one at a time. How do I get to and replace the bulbs? Thanks.
Old 05-03-2005, 04:31 PM
CHRISTIANMAN316 CHRISTIANMAN316 is offline
CHRISTIANMAN316 is starting off with a positive reputation.
I Am Having The Same Dadburn Trouble Out Of My 2001, Let Me Know When You Find Out. Thanks.
Steve
Old 05-03-2005, 04:35 PM
OK. Hopefully someone helps us soon or we'll be needing one of those miner's helmets that has a built in flashlight on the top of it. Yikes!
Old 05-03-2005, 04:40 PM
basstardo's Avatar
basstardo basstardo is offline
basstardo is starting off with a positive reputation.
I dunno how these trucks are, but my 93 Ranger was a real PITA. I had to take the entire dash off and part of the guage cluster to get to it. I'll look in the Haynes manual tonight and see if I can't find anything, but more than likely you'll have to tear the dash apart.
Old 05-03-2005, 05:49 PM
Thank you for your help and quick reply.
Old 05-03-2005, 06:03 PM
doreilly's Avatar
doreilly doreilly is offline
doreilly is starting off with a positive reputation.
Yes
I had to replace bulbs in my f250 and I had to take the dash apart. If I remember correctly it was kind a tedious clumsy job and was kind of tight to get the bulbs out because they are sunken in a fair bit.
Old 05-03-2005, 09:09 PM
Brian0445 Brian0445 is offline
Brian0445 is starting off with a positive reputation.
Smile
I had the same problem on my 99 f-350 with a powerstoke. It was easier than i thought. You will have to take your dash apart. First i removed mu radio so that you can take the dash right out of the way. On mine to remove the head/marker light plug there were red clips that held the plug into the socket, move them and pull plug out of the socket, now the dash should come out. There are 2 screws that hold the instrument cluster to the mounting bracket on the bottom remove them and the instrument cluster should be able to be move to get at the back of it. With a small pair of pliers remove the lights that are bad. there where held in with a tan type socket just twist it with the pliers. Most of the sockets are marked on the rear of the intrument cluster.
Old 05-05-2005, 07:54 AM
Scruffy's Avatar
Scruffy Scruffy is offline
Scruffy is starting off with a positive reputation.
Dash lights
I have the same truck as you, 01 f-250 S.D. ext cab with 138000 miles. My dash lights started going out on me also about a year ago. First one then another and another, all starting from the left moving to the right. I have three out now. I drive a lot of dirt roads so I though the bouncing around did it. I had to go to the dealer to order them and they gave me the wrong ones at $4 apiece so be sure to get the right ones, there are two different sizes back there. To fix them you do have to remove the radio first. Good luck.
1. Using the special anti theft tools (allen wrenches or similar objects that fit snug in the holes) will push the locking feature out of the way.
2. Remove the two screws at the top of the radio hole. They hold the dash on.
3. Using a screw driver CAREFULLY go around the dash and pry the retaining clips loose. They just push into slots to hold the dash in place.
4. Once you have it loose disconnect the wiring plugs and move the dash cover out of the way.
5. Now you can remove the screws that hold the instrument cluster and get to the bulbs.
6. As far as reinstall well I think you can figure that out.
Old 05-05-2005, 07:42 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
Just a thought, but why you are in there, I'd change all of the bulbs so you don't have to do it again.
Old 05-06-2005, 03:54 AM
Scruffy's Avatar
Yea you bet, great advice. I haven't ordered the correct bulbs yet but I am sure they are just as spendy as the other bulbs back there.
Old 10-19-2010, 06:24 PM
glass_joe099 glass_joe099 is offline
glass_joe099 is starting off with a positive reputation.
I am assuming that the removal and installation is the same for a 1998 F-250 with a 5.4 V8 engine? It would suck if it wasn't.
Old 05-23-2012, 11:19 AM
01Two50 01Two50 is offline
01Two50 is starting off with a positive reputation.
Anyone know of the lightbulb part number to get? I dont want to have to take it apart just to see, put it back together, then order the bulbs, and have to tear it apart again.
Old 05-23-2012, 03:05 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
I bought mine at O'Reily's from their chart (can't remember the number). I want to think it takes something like 14 to replace them all (dash illumination and alerts all the same), but I can't remember the exact number. Just buy a bunch and keep the receipt.
Old 05-23-2012, 08:46 PM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
The illumination bulb number is 194LL (Long Life)
Old 05-23-2012, 08:55 PM
Quote:
Like these?
#194LL Miniature Light Bulbs ( Box of 10) 14 V / .27 A
http://bit.ly/Je5i01
07 F250 4wd Dash Light Replacement BlackTruckDave Electrical Systems/Wiring 1 12-13-2016 11:37 AM
Dash lights out help greenmachine86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 08-28-2016 08:10 AM
SERIOUS light issues old blue beast 1987 - 1996 F150 & Larger F-Series Trucks 3 08-05-2016 09:28 PM
1997 F250 Heavy Duty CLEAN & WELL Maintained truck7575 Vehicles for Sale 1 04-09-2015 10:54 PM
O5' Headlight switch bulb bbdano 1999 to 2016 Super Duty 5 03-17-2008 04:15 PM
Tags
1996, 2000, 2001, 2003, 99, bulb, bulbs, dash, f250, ford, instrument, light, lights, panel, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
