Alignment concern with RAM welded to TR
It's about time for new tread. I have abnormal tire wear that started after awhile back. I did have bad wheel bearing units that have since been replaced and the wear hasn't seemed to worsen.
I am thinking of getting an alignment prior to new shoes to protect the investment but I have welded my hydraulic RAM to my tie rod per the recommendation of West Texas Off Road. I am contemplating the following fork in the road:
- grind the mounting ears off and buy the clamp mount that WTOR now trusts to not slide on the TR
- buy a new tie rod and the clamp
-forego the alignment for now as the wheel feels pretty true and maybe the bad bearings were the cause of my abdormal tire wear (?)
What say you?
What say you?
The following users liked this post:
Possible the issue you seen was for 05+ f250? They have different tie rod that has 2 short end sand a long adjusting in the center where you would mojnt the ram. That style would have issues like you were referring to in first post.
What say you?
What say you?
EDIT: found the clamp...for the price. I re-weld. https://the4x4garage.square.site/
Get the alignment then check the rod. If you need to adjust it, cut and re-weld the ram mount ears. Or get the clamp on. Don't over think this one...
seymour
06-11-2002 10:58 AM
