F250 Dash light bulb replacement
The main dash lighting bulbs are 194 (whatever the letters after the number are). I believe there are 6 in the dash.
You can get LED bulbs to put in those places, but remember, LED lights are polarity sensitive. If they dont work the first time, turn them 180.
The smaller indicator bulbs are 37 bulbs. LEDs work here as well.
Follow the directions from scruffy to get to them.
Wow, I guess I shouldnt try to copy and paste links on my phone. Sorry.
This is what it was supposed to be...
#194LL Miniature Light Bulbs ( Box of 10) 14 V / .27 A | eBay
Or these as Led's...
10x T10 W5W 194 168 501 Car White 20 SMD LED Inverted Side Wedge Light Bulb 12V | eBay
When getting LED lights for the dash lighting, get the ones that emit the light out of the end of the bulb. The instrument panels on Ford trucks use light pipes to direct the light to the panel front. Using end emitting lights puts the most light toward the front panel. Side emitting bulbs are not as effective. Also make sure they are dim-able.
If you are getting the LED bulbs for turn signal or marker lights, the side emitting ones are best. They fill the lens.
The ones you linked to will work, but they won't be as bright.
This thread has some good info and links on led dash lights and changing colors
https://www.ford-trucks.com/forums/1...ght-color.html
I tried to post a pic of what I bought, i can send them to you by email or to your phone if you message me. It would probably be more helpful than me explaining it but I'll try anyway.
I got mine from NAPA and the different part numbers get confusing, but basically you're looking for a little 194 for any of the indicator lights. I have a "service engine soon" light under my tachometer and not a "Check Engine" light and that took me a while to figure out. There were a total of 18 of these smaller lights on my truck (2000 f250 4x4 automatic), and 5 larger lights. The larger lights just illuminate the gauges and the smaller lights do each individual indicator (like "Door Ajar", "Low Fuel","Brakes" etc), as far as I could tell.
The smaller lights are these LMP 194s at NAPA. And these are just the lights, not the plastic piece the light bulb sits in (or snaps in) that you screw in and out of the back of the instrument panel. So only having the lights I had to pop some of the bad bulbs out and replace them with new ones. The 5 larger lights I bought had the bulb and plastic seat so I just replaced the whole thing.
#29
Anybody shopping at Advanced for 194 bulbs, they have a box of 10 behind the counter for under $3.
5 194 for cluster illumination. Bunch of warning/indicator small bulbs I didn't replace.
While its apart grab the a/c bulbs and replace.
Door courtesy light are 194 too.
New bulbs are worth the effort for the bright dash. Had at least 2 bulbs out.
#30
It will prob go another 8 with these trucks getting older. But I am impressed how many guys on here use the search function to find answers instead of seeing the same thing over and over again.
