Bank Of Injectors Not Working Help!
I have E350 2000 7.3L.
Replaced Turbocharger
After turning over it finally started, however the left side of engine only works.
Checked wiring harness and fuel lines for kinks.
I have about 10volts on the Glow Plugs.
What is the voltage across a typical injector?
Do I need an oscilloscope to see PWM or will a VOM pick up some similar voltage?
Thanks, it did work well before the turbo went bad. It took along time to prime.
I checked the injector common to ground and got less than 3 volts, however it is extremely difficult to check or compare the good side with the side that's not working.
Do you know what could cause a problem like this?
Originally Posted by cookie88
It's almost gotta be in the harness somewhere, or the UVC connectors. The IDM is just an amp. The PCM tells it to fire and it fires, pretty unlikely that it would only misfire on one bank.
Duncan
1983/84f350
03-22-2012 08:15 AM
