Any Suggestions
Any Suggestions
I just became a new V-10 Excursion owner. I work at a salvage yard and came across an awesome deal on this 2000 Excursion with a bad engine. I can buy a used engine for 1700 with 75k or 1500 with 94k. Just wanted to know if anyone has any other suggestions on cheap long blocks or anything else. Of course I am trying to get out with the best bang for the buck. I am just ready to put this engine in so I can get this beast on the road. Also according to my computer the block is different from an 02+. Can these be used? What modifcations are required? Everything but the block and the timing cover show to be the same for all years (of course heads were improved in 02 but still fit all years.) The X has 95k on it and is locked up. My mechanic has not got it out yet to find out what broke. Being new to these is there any common things to watch out for? Is that used one with 94K going to be on its last leg already? I know freak things happen, and from what I have read these should be good for a long time if taken care of. Thanks
Wecome to the site and some guys with more V10 smarts than I have will be around to give you more advice. I know the 00 and newer motors make more power than the earlier
V10s and with all the computer stuff on these newer vehicles an engine swap is not as simple as it was when I was a boy. Good luck . Wrenchtraveller.
Originally Posted by V10X
I just found the one I think I am going to go for. Its out of a 00 F350 so the power ratings will be the same and the engine only has 68K. I can get this to my door for 1500. I think I am going to order this on Monday unless someone comes up with something better.
My buddy has not torn down that engine to find out what happened yet. He is afraid for whatever reason that the engine lost oil pressure. I am new to these, but from what he told me the instant these engines lose oil pressure since there are no cam bearings the heads are junk. I will keep ya'll updated on what extra parts I come up with.
V10X
I beeen trying to tellin folks for 5 years to pay real close attention to lube and schedule.
Funny thing about motors that use the aluminum as the bearing... taint not tolerence for heavy lube or dirty crap....
There are five rotating assemblies in these bad boys and they all run in aluminum including the crank!
