running on alcohol
Old 05-02-2005, 02:07 PM
fordguyforlife's Avatar
fordguyforlife
fordguyforlife is offline
running on alcohol
does anybody no what exactly it takes to convert an engine to run off of alcohol?
Old 05-02-2005, 06:34 PM
Bronco2Nic's Avatar
Bronco2Nic
Bronco2Nic is offline
I was woundering the same thing because me and my buddies say that if gas pricesses go up much more then were making a still in my buddies backyard.
Old 05-02-2005, 10:01 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Moved to proper forum.
Old 05-02-2005, 11:33 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Well, it depends on a few variables, such as what vehicle you want to convert, where you live, and how well you want it to work.
Basically with alcohol, you need to run it richer. For a carburetor, this means changing jets. For a fuel injected vehicle, this means reprogramming the computer.
Where you live has a lot to do with it also. Alcohol doesn't vaporize as readily as gasoline. In cold climates, this can be a real problem when it wont start in the morning. Most E85 capable vehicles use heated intake manifolds to solve this. On a conversion, you might want to figure out a way to start it on gasoline then switch over. Of course, if you live in Texas, then never mind.
Alcohol motors will really benefit from an increased compression ratio. This would involve rebuilding the engine and modifying the internal components. This is what you have to do if you want to get equivalent mileage as gasoline. Basically you use a high static compression ratio, around 12 to 1, with a small cam, to create a high dynamic compression ratio. This will extract the most possible power, and thus mileage, out of the alcohol.
Anything else?
Old 05-03-2005, 12:24 AM
fellro86's Avatar
fellro86
fellro86 is offline
ADM did a study back in the late 70's with a Ford Fiesta, and they brought the compression up a bit, rejetted the carb, and set up a washer bottle filled with gasoline to give a shot of gasoline to the carb to make it fire. Beyond that, it ran fine with just those mods, and was getting pretty good mileage, better than it had gotten with gasoline alone. I did a paper on it back when I went to college, but unfortunately do not have the paper and the info at hand anymore.
Old 05-20-2005, 05:25 PM
meatybtz's Avatar
meatybtz
meatybtz is offline
well, i ran my ford off of a can of Eth ( E100) i had distilled and molecular sieved to 100%, only thing i changed was my jets. Ran great, and cool too. Rejetted hooked back up the fuel line and drove off with gasoline. The simple least efficient way is to simply rejet your cab to compensate for the different air-fuel requiremetns, the rest is just filling a tank. Unless you have very cold weather, being a californian, i dont have that problem. Corse, i am runing on gas now again.
Old 06-05-2005, 10:58 PM
Triel's Avatar
Triel
Triel is offline
I am getting ready to make some major mods to my 2001 Cal F150. I will be testing how far I can take the engine, in Alcohol %, before problems. Then I will start modifying and adding new parts till I get to 50% or higher. When I am done I will list everything I did or provide a link. The reason for this is simple.
I have a 2001 4X4 F150 with Triton 5.4L. I only get 13.5 to 14.5 mpg in it regardless of how hard I drive. I once took a trip from NC to Daytona, FL and was driving between 70 and 85 on I95 (to keep from getting ran off the road). That trip only resulted in 15mpg. When I moved from Califonia I towed another vehicle on a trailer. Weight of trailer and towed vehicle totaled 7500 lbs. My truck got avg 14mpg. That is dam good since I was maxed out on GVWR and had more power then I needed.
Old 06-06-2005, 07:19 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Triel, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 07-29-2005, 10:02 AM
jwbowen's Avatar
jwbowen
jwbowen is offline
Triel,
You might start your mods by seeing if the chip from a CrownVic/Merc Marquis can be installed in your F-150. They run the 4.6/5.4 engines and already are dual fuel vehicles (DFVs). In other words, they will run any blend of gasoline and ethanol up to E85 without changing anything. When you make a big shift (from E10 to E85, say), they idle roughly and stumble for a few seconds until the chip figures out what it's burning. Then you're good to go.
Note that Ford doesn't promote these as DFVs. Wonder why?
Old 07-29-2005, 05:04 PM
351M's Avatar
351M
351M is offline
I'm guessing that the injectors are different for E85 though. So he may need to swap those as well as a few other fuel system components out.
Old 08-07-2005, 07:28 PM
NeilJames's Avatar
NeilJames
NeilJames is offline
I geuss from what I've noticed from being in the sprint car world for a few years it's Bigger jet's. and Dang Methenol is Expensive.
daddy172005
16
02-20-2020 07:08 PM
FTE Ken
Alternative Fuels, Hybrids & Mileage
35
03-02-2009 01:54 AM
LedheadELH
16
03-14-2007 11:58 AM
uuranium
05-10-2006 06:09 PM
jay_birdys
06-21-2003 10:53 PM
Quick Reply: running on alcohol
