You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
does anybody no what exactly it takes to convert an engine to run off of alcohol?
Well, it depends on a few variables, such as what vehicle you want to convert, where you live, and how well you want it to work.
Basically with alcohol, you need to run it richer. For a carburetor, this means changing jets. For a fuel injected vehicle, this means reprogramming the computer.
Where you live has a lot to do with it also. Alcohol doesn't vaporize as readily as gasoline. In cold climates, this can be a real problem when it wont start in the morning. Most E85 capable vehicles use heated intake manifolds to solve this. On a conversion, you might want to figure out a way to start it on gasoline then switch over. Of course, if you live in Texas, then never mind.
Alcohol motors will really benefit from an increased compression ratio. This would involve rebuilding the engine and modifying the internal components. This is what you have to do if you want to get equivalent mileage as gasoline. Basically you use a high static compression ratio, around 12 to 1, with a small cam, to create a high dynamic compression ratio. This will extract the most possible power, and thus mileage, out of the alcohol.
ADM did a study back in the late 70's with a Ford Fiesta, and they brought the compression up a bit, rejetted the carb, and set up a washer bottle filled with gasoline to give a shot of gasoline to the carb to make it fire. Beyond that, it ran fine with just those mods, and was getting pretty good mileage, better than it had gotten with gasoline alone. I did a paper on it back when I went to college, but unfortunately do not have the paper and the info at hand anymore.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
well, i ran my ford off of a can of Eth ( E100) i had distilled and molecular sieved to 100%, only thing i changed was my jets. Ran great, and cool too. Rejetted hooked back up the fuel line and drove off with gasoline. The simple least efficient way is to simply rejet your cab to compensate for the different air-fuel requiremetns, the rest is just filling a tank. Unless you have very cold weather, being a californian, i dont have that problem. Corse, i am runing on gas now again.
I am getting ready to make some major mods to my 2001 Cal F150. I will be testing how far I can take the engine, in Alcohol %, before problems. Then I will start modifying and adding new parts till I get to 50% or higher. When I am done I will list everything I did or provide a link. The reason for this is simple.
I have a 2001 4X4 F150 with Triton 5.4L. I only get 13.5 to 14.5 mpg in it regardless of how hard I drive. I once took a trip from NC to Daytona, FL and was driving between 70 and 85 on I95 (to keep from getting ran off the road). That trip only resulted in 15mpg. When I moved from Califonia I towed another vehicle on a trailer. Weight of trailer and towed vehicle totaled 7500 lbs. My truck got avg 14mpg. That is dam good since I was maxed out on GVWR and had more power then I needed.
...Welcome Triel, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
You might start your mods by seeing if the chip from a CrownVic/Merc Marquis can be installed in your F-150. They run the 4.6/5.4 engines and already are dual fuel vehicles (DFVs). In other words, they will run any blend of gasoline and ethanol up to E85 without changing anything. When you make a big shift (from E10 to E85, say), they idle roughly and stumble for a few seconds until the chip figures out what it's burning. Then you're good to go.
Note that Ford doesn't promote these as DFVs. Wonder why?
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
