Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-01-2005, 09:30 PM
Bill Hanson Bill Hanson is offline
Garage is empty, add now
Bill Hanson is starting off with a positive reputation.
68 Ford Falcon, Wire harness
I am detailing under the hood of my 68 Falcon. I would like to remove the main wire harness. Where it goes through the fire wall all the wires go through a square box flush mounted to the firewall. On the other side is the fuse box under the dash. Is this square box a plug that can be pulled appart? I gently pryed on it with a screwdriver, but was afraid to damage something. If I knew it was a plug for sure I would go at it more agressively. I hope someone has been down this road before. Thanks Bill.
  #2 (permalink)
Old 05-02-2005, 07:48 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
Usually tjhey are a junction box from the passenger compartment to the engine compartment. They usually can be pried apart, but are fairly tight and most have ascrew or small bolt in the centre to keep them sealed and from coming apart. They also have a caulking to help seal around the firewall to prevent moisture coming in or corroding the connections. They also may have plastic tabs that lock them together.
Check around it and go slow so you do not do a lot of damage,You then may not be able reconnect properly.Click the image to open in full size.
  #3 (permalink)
Old 05-02-2005, 08:34 PM
Thanks for your information. Bill.
Tags
falcon, ford, harness, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
