Engine Oil Dip Stick - Ford Truck Enthusiasts Forums
Old 05-01-2005, 07:36 PM
red56flatty red56flatty is offline
red56flatty is starting off with a positive reputation.
Does anyone know of a manufacturer that makes an oil dip stick and tube for the 272/292/312? I have a '56 F350 with a 272 and mine is pretty bad. The tube is on the passenger side about in the middle of the block. It has a tab welded on it to secure it to a boss on the block.
Thanks
Old 05-02-2005, 08:00 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
red, don't know anyone making the dipstick assembly. I had the same problem. Ended up pulling the stock assembly, bought a new dipstick at the parts store, and pieced the new and old together with some welds. Then cut the stick to length. It wasn't hard, but maybe someone else has an easier way.
Old 05-16-2005, 08:13 PM
46yblock's Avatar
Just saw a new stainless steel dip stick tube offered on e-bay. So someone is making them now. It requires the use of the stock stick however.
Old 05-27-2005, 08:51 PM
46yblock,
Thanks for the input. I'll have to check e-bay or make one the old fashoned way as you described.
Oil dip stick tube help dkj313 1967 - 1972 F-100 & Larger F-Series Trucks 10 03-17-2017 05:29 PM
97 F250 OIl leak & dip stick problem CapePowder 1997 - 2003 F150 6 09-08-2016 09:13 PM
WTB: 1964 Ford F100 292 Oil Dip Stick SanDogDewey WTB - Parts & other 0 02-01-2016 10:00 AM
Dip Stick question tanman722001 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-10-2013 07:50 PM
oil leak at the dipstick tube tstorm FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-20-2011 11:07 AM
Tags
292, block, dip, ford, oil, stick, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
