Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #16 (permalink)
Old 09-15-2006, 02:35 AM
200000+F150 200000+F150 is offline
200000+F150 is starting off with a positive reputation.
Is the horsepower rating of the compressor strictly that of the motor, or are there other factors involved? I also didn't know about a Sears lawsuit. What's up with that? I've got an older Craftsman 5hp with the 30 gallon tank, 125 PSI max, CFM rating unknown. Anyway, it's been sitting around for a couple of years with a cooked motor. I need to start doing some bead blasting soon as part of a new business. I've got an old nameless blast cabinet as well, that I've only used once (just to test it, running off a bottle of nitrogen). I have no idea what the nozzle size is, or anything else. Anyway, just last week I got a new motor(5HP GE) at TSC, installed it and a new belt, and am quite happy to have air again. (been finding excuses to use a drawer full of air tools that have been collecting dust). I knew when I bought the motor that the compressor was really too small for blasting, but was hoping to "get by" until I can make enough money to upgrade. Listening to this thread, I'm a little scared that I won't even be able to do that. I was planning on getting the IR 7hp single stage 100 gallon unit that TSC sells (my brother has one and loves it). Should I go for a two-stage, and if so, any recommedations?
__________________
People who say "violence never solved anything" obviously slept through history class.
94 F-150 Long Bed
White Base Model "Fleet Special"
300 I6/5spd.
95 F-150 Extended Cab
300 I6/auto
  #17 (permalink)
Old 09-18-2006, 03:53 PM
rlh's Avatar
rlh rlh is offline
rlh is starting off with a positive reputation.
Good News/Bad News
The good news is that the 60 and 80-gal kobalt compressors are not made by CH and are American made with 3 year warranty. The bad news is that Lowes is going to quit carrying the 80-gal 2-stage. The Home Depot Husky large 2-stage compressors are CH and it even says so on the unit.
Harbor Freight has those U.S. Generals with units of varying specs but don't seem to match the Kobalt 80-gal. The other option is to order an Eaton.
Edit: I bought one of the Kobalt 80-gal 2 months ago and so far so good. It is quite. It was supposed to require a 40 amp breaker and it has been working on the existing 30 amp breaker. I'm suprised by that. Also, that is the first time I've paid to have anything delivered but that was $50 well spent. It weighed 500pouns and was top heavy. They put it on the outside covered platform for me.
__________________
1990 Bronco XLT 302/AOD
1986 F350 Crew Cab XL 460/C6
1986 Bronco XLT 351W
1981 Bronco Custom
  #18 (permalink)
Old 09-19-2006, 09:38 PM
rlh's Avatar
rlh rlh is offline
Also, the 45, 60 and 80 gal Kobalt K7045V, K7060HFV, K7580V2 are made by
ABAC American, spedifically Bellaire. AMAC American
__________________
1981 Bronco Custom
  #19 (permalink)
Old 10-18-2006, 07:45 PM
wd2400 wd2400 is offline
wd2400 is starting off with a positive reputation.
After purchasing a Kobalt 7hp compressor it died after 6 months and they will not service it. Nice 3 year warranty.
skippy
  #20 (permalink)
Old 10-18-2006, 11:11 PM
rlh's Avatar
rlh rlh is offline
Wow. Your first post.
__________________
1981 Bronco Custom
  #21 (permalink)
Old 10-19-2006, 01:48 AM
fixnair fixnair is offline
fixnair is gaining momentum as a positive member of FTE.
FYI! Compressing air up to 100 PSIG increases its temperature 600°! In practice there are several cooling devices employed on air compressors so the discharge line only sees probably 325°. Still too hot for nylon tubing.
By the way that heat of compression is what makes your diesel operate. When you compress air to around 350 PSIG ( typical for a diesel ) its temp is probably 1500°. (only guessing here )
Steve
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
Tags
17 , 175 , 20 , 20gal , 45 , 60 , 80 , air , compressor , gallon , kobalt , lowes , psi , regulator , reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
