shocks for 1994 f150 - Ford Truck Enthusiasts Forums
Old 05-01-2005, 12:47 PM
fordtruck88's Avatar
fordtruck88 fordtruck88 is offline
fordtruck88 is new and has a neutral reputation at this point.
I have a 1994 f150 reg. cab 4X2. I need shocks and was loking at monroe shocks. has anyone used these and liked them before? if not, what brand did you use. im not looking for a lift or anything , just a good regluar height shock
thanks
Old 05-01-2005, 07:26 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
Which monroe shock? and what type of driving do you do?
Off roading would require a different type of shock than a strictly asphault one.
In the meantime, I've heard some really good things about Monroe's Radix line of shocks. I have been considering putting them on my wifes car.
Cheers,
Popa Tim
Old 05-01-2005, 07:40 PM
Dad's Truck Dad's Truck is offline
Dad's Truck is starting off with a positive reputation.
Thumbs up
I put Gabriel Ultra LT shocks on my '92, and I like them a lot. And at $26 each (minus my discount), not a bad deal. Lifetime warranty and all, through AutoZone.
Putting rotors and pads on tomorrow...
Old 05-01-2005, 09:02 PM
924x2150's Avatar
924x2150 924x2150 is offline
924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.
I am unhappy with sears sensatracs all around on my 92 4x2 F150. The handling is good, but they do not stop all the little bumps in the road from annoying me. I can literally feel each 1/4 inch wide crack, bump, or hole. Poorly paved roads are the worst. When I drive home from Work and I'm tired it really bugs me to get bounced around so much. These are the second set of shocks I owned, the Ford factory shocks felt fine until they started leaking, then I put the sensatracs on and was immediately unhappy, I waited for them to break in, with no luck, and then complained to Sears, they said I had the right shocks, but a few people here at FTE said they are passenger car shocks and are underated for my truck.
Remember, they are called "shock absorbers" you do not want to feel every pothole, it ain't fun.
Old 05-01-2005, 11:11 PM
[QUOTEWhich monroe shock? and what type of driving do you do?
Cheers,
Popa Tim
[/QUOTE]]
I was thinking the sensormatic ( i think its called that) i do mostly unloaded city driving.
thanks for the replies
Old 05-01-2005, 11:17 PM
sixstick94 sixstick94 is offline
sixstick94 is starting off with a positive reputation.
I work at sears as a technician and we have had complaints about sensa-trac truck shocks being too stiff of ride. I purchased monroe gasmatics from sears and they work great, cheaper than sensatracs too. Also on my ranger I used the Gabriels from autozone, they work well too, but then again my ranger has really stiff aftermarket springs so they don't travel much.
Old 05-02-2005, 08:11 PM
924x2150's Avatar
sixstick94, that is my problem exactly. I thought Monroe and sensatrac were the same, or built by the same company!
Old 05-03-2005, 12:51 AM
Sensatrac and Gasmatic are both models of shocks from Monroe, the gasmatics are considerably cheaper and I have no complaints with them. (As a sidenote, my F150 had sensatracs on it before, but they were worn and I got the gasmatics at 50 bucks for the set of 4 when they were on sale)
Old 05-05-2005, 09:42 AM
grantorino74 grantorino74 is offline
grantorino74 is starting off with a positive reputation.
Shocks
SIXSTICK94 - I looked on the MONROE.COM site and they had a "GAS-MAGNUM" shock used for mid to full size "hard working" trucks and also a "MONRO-MATIC PLUS" which is a nitogen-gas charged shock. They did not have a "GASMATIC" shock. I believe they discontinued that shock or redesigned it a little and now call it something else. Do you know what it is called now? I just use my 94 150 for in town driving and do now want to stiff of a ride. I still have the original ford shocks which are now leaking. I think these leaking shocks cause the front end to shimy when I stop a little hard on a rough road. I have new brakes/rotors on the front so I am guessing it is the shocks as everything else checks out ok.
Old 05-06-2005, 09:05 PM
gresebaul gresebaul is offline
gresebaul is starting off with a positive reputation.
Two years ago, got a set of Monroe Sensa Trac shocks ( all four wheels) installed at Sears. They really helped the handling and only firmed up the ride a little. Cost $36.99 ea. with free instillation. I'm happy with them. Regards, gresebaul
Old 05-06-2005, 09:23 PM
my bad... its not radix , its monroe Reflex shocks. They supposedly respond 100x faster than their sensotrak line.
sixstick94, have you had any experience with these?
Old 05-06-2005, 10:00 PM
95_4x4_jay's Avatar
95_4x4_jay 95_4x4_jay is offline
95_4x4_jay is starting off with a positive reputation.
What about Ranchero or some other brands?
I do 95% paved road.
I would like a soft gentle ride for once. I feel everything.
Also my truck has two shocks per side in the front. Do most have that setup?
Old 05-09-2005, 11:09 AM
88F-150pimp 88F-150pimp is offline
88F-150pimp is starting off with a positive reputation.
I have these CarQuest VST shocks. They were like $35 apiece and are supposed to have some valving that changes with terrain. They ride pretty nice on my wasboard and pothole gravel road, at least better than anything else except ultra soft supension old-people cars. They are decent on pavement. I like them.
Shocks lvethelake 1997 - 2003 F150 2 07-30-2016 09:19 AM
Shock tower mount rockyrunner99 1987 - 1996 F150 & Larger F-Series Trucks 2 04-03-2016 02:04 PM
Load Adjuster Shocks didn't fit m1rjj00 1987 - 1996 F150 & Larger F-Series Trucks 3 09-09-2015 10:50 AM
replacing shocks 96 f150 FordYoungGun35 Brakes, Steering, Suspension, Tires, & Wheels 0 02-13-2013 12:22 PM
F-150 shocks, KYB Monomax irwin25 1987 - 1996 F150 & Larger F-Series Trucks 1 02-13-2007 03:45 PM
Tags
1994, f150, good, shocks, stiffer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
