ignition wiring
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Does this have the 351 mod? I have a 78 F-250 that drove me up the wall when I was fixin it up cause everytime I would drive it it would run great for 10-20 mins then die. I thought it was the coil and it ended up being the Dist. I replaced everything up to the dist then finally the dist and the problem went away. Best part was it was like 46 bucks for the dist.
