Bad COP ?
Bad COP ?
Hello , I have a 97' F-150 V8 5.4 4X4. I changed the plugs about 2 months ago and it was running fine. It started acting up again (mis-firing). I went to auto zone and had it tested. They said the #5 cyclinder was the problem. I took out the plug and it was wore down pretty good. I replaced the plug but it still runs quite rough when accellerated.When I first start the truck it seems to run fine after a few minutes of driving it starts acting up. Should my next step be , Change the COP on the #5 cyclinder or is their a whole nother problem ? Thank You for your time. Forgot to add that I replaced the plugs with Motorcraft Platinum
Last edited by Hammer19; 04-27-2005 at 09:43 AM. Reason: forgot to ad some information
zzzJohn
01-15-2012 12:30 PM
