92 Explorer transmission shift cable - Ford Truck Enthusiasts Forums
Old 04-27-2005, 05:32 AM
explorer5258 explorer5258 is offline
explorer5258 is starting off with a positive reputation.
Having trouble shifting; sometimes I could and somestimes I couldn't. I thought the problems started after I let my 17 year old son drive it for a few days. I thought he might have jerked the shift handle hard and broke or bent something in the steering column. After two days of my spare time used disassembling the steering column and not finding anything broke, I look closer under the hood and the transmission linkage. I noticed full range movement from the column mounted shift handle out to the end of the steering column. I noticed that if I pushed the transmission likage by hand the column shifter would get it back to park? This happens because moving the column handle from the drive position to the park position pushs the cable. When moving the column shift handle from park to any other position pulls the cable. So I have a broken cable. And I did say I put the blame on my 17 year old son, turns out I burnt it into while jump starting other vehicles I have. Ford now makes this cable with plastic ends so it won't carry a ground. Hope this helps someone out with like problem.
81 F100 3 on tree steering column ? 66_in_ky 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 02-09-2015 03:05 PM
Steering Column Near-Death Experience, Learn from my mistake. landmobile 1999 - 2003 7.3L Power Stroke Diesel 13 02-04-2015 02:47 PM
Heater core tips/new problem 93 mix 'n match 1997 - 2003 F150 1 01-18-2011 02:28 PM
transmission cable adjustment Muv Clutch, Transmission, Differential, Axle & Transfer Case 5 03-31-2008 01:09 PM
1997 Ford Explorer possible shift cable problem. Terryfromok Explorer, Sport Trac, Mountaineer & Aviator 0 10-07-2005 10:25 PM
Tags
92, cable, explorer, f150, linkage, shift, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
