New Intake and Throttle Body spacer
if you are looking for better gas milage, then the spacer and intake are good. if you are wanting performance, i would skip the spacer. i had one and pulled if off. it did not add any power from what i can tell. i added a 75mm throttle body and got a lot more power. with spacer you can't go with larger throttle body. hope this has been a little help.
furrby
furrby
Originally Posted by justinhorn
I have a 03 F-150 4X4 and was wondering if there is any company besides K&N, Air Raid or anything other than big name companys. I wanted to support the little man. Any suggestions??? If not give me your suggestions on what i should put on there??
Originally Posted by mel2000f150
Furrby
Where did you get the 75mm throttle body and how hard of a job is it to do. Mel
Hope this helps
John
99 f-150 4x4 ext. cab(84k)
rear steel buper..grilleguard w/4 KC lights
tool box..bed linner
dual exaust..K&N air intake...<!-- / message --><!-- / message --><!-- / message --><!-- / message --><!-- / message -->
Furrby
Hope this helps
John
my dads got an 02 supercrew with the 5.4, he added the K&N FIPK and a Borla dual exhaust, the air filter alone gave him better acceleration, but if your sucking in all that air and cant get it out quick enough, then its not that effective. so when he put the exhaust on it, it was like night and day with power, not really loud either...its gives it a nice throaty sound and on the highway he gets between 2-4 mpg better. hes got the 3.55 and doin 80 hes getting 14-15 and thats towing a 2000 # trailer or not, sometimes goes down if your hittig headwind with the trailer, but while doin 60-65, the best he got was 21 mpg......and from whaat furrby said, i think ill look into the throttle body for him, speaking of that, what engine do you have furrrby?? if its the 5.4, do you think you can tell me the part number and that so i can find it? thanks
