Driveshaft Balance Collar? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-25-2005, 09:34 PM
maticuno's Avatar
maticuno maticuno is offline
maticuno is starting off with a positive reputation.
Hey, quick response would be much appreciated here. After a bit of off-roading I noticed a horrible grinding noise which I thought was my tranny. I changed my oil and noticed this: http://www.maticuno.com/pictures/drivecollar.jpg
while underneath. Happy it turned out to be this instead of a bent input shaft and shattered second gear as I was originally thinking. I'm guessing it is some sort of balancer for the driveshaft. What I'm wondering is...since my truck is running just great (minus the grinding) without it...do I even need it? Can I just drop the driveshaft and remove it with no problems? Or should I have the shop replace it?
Old 04-25-2005, 10:46 PM
Help I M Stuck Help I M Stuck is offline
Help I M Stuck is starting off with a positive reputation.
looks like it might have been pressed on there at one time and worked itself loose..can you take the flange yoke off and press it back on?
Old 04-26-2005, 08:58 AM
maticuno's Avatar
I don't have anything to press it on with. Tapping it with a hammer was inneffective. That's about all I could try with the limited tools at my disposal.
Old 04-26-2005, 09:53 AM
take the two pieces off and take them to a shop and have it pressed back on..should only cost a few dollars.
Or..
If u only use the truck for offroading..take it off and wheel on!
Old 04-28-2005, 12:14 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
It is just a vibration dampner. It might play some small part in balancing the driveshaft, but it is just really there to reduce sudden shock movements through the drivetrain.
Pull the driveshaft and take it off. Drive around and see if you notice any difference without it on there. It is only attached to the yoke with some rubber and that's why they are prone to breaking. If you really, really want to fix this, you'll have to buy a new yoke that has the dampner on it.
Old 04-28-2005, 10:34 PM
maticuno's Avatar
Thanks for the input. Already took it off and I don't notice any ill effects. There are some (relatively) massive chunks taken out of the collar. I don't know how my ALUMINUM tranny case could have made those marks...but it has the matching bites to show it. I think I'm going to keep the part as a cupholder or a paperweight as a monument to one of Ford's more lame ideas.
Old 02-21-2010, 05:51 PM
mazdazoomzoomtruck mazdazoomzoomtruck is offline
mazdazoomzoomtruck is starting off with a positive reputation.
i drive a mazda had the same problem trust me it will get worse after a few months
id take off the shaft and take it to a drive shaft shop they will rebalance the shaft and the truck will be back to its normal self
Old 02-21-2010, 10:57 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Yep have the shaft rebalanced with out the Harmonic damper. It should be good to go.
Driveshaft balancing SoCalJim 1997 - 2003 F150 4 05-09-2014 11:33 AM
Driveshaft problems Alex Bindas 1987 - 1996 F150 & Larger F-Series Trucks 3 03-16-2014 05:23 PM
driveshaft bolt size Headviking 1999 - 2003 7.3L Power Stroke Diesel 12 06-19-2012 11:25 AM
driveshaft balance powerstroker100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 08-01-2010 10:15 PM
Custom Hard Hats! maticuno General NON-Automotive Conversation 16 10-08-2005 05:16 PM
Tags
2001, 97, balance, balancer, balancing, collar, delaware, drive, driveshaft, f150, ford, prerunner, pull, ranger, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
