Clunk instead of start, Starter AGAIN?
This morning when I went out to leave for work my Bronco made 2 slow clunks when I turned the key and then everything went dead. I lost all battery power completely. If I leave it sitting for a while and try again I will have battery power until I try to turn the key, at which time I get a clunk and then everything dies again. I tried jump starting it with no change. I changed the starter out probably 6 months ago. The battery was also replaced around the same time. Does it sound like the starter would be the most likely problem again? Thanks.
