Ticking noise in motor ????? - Ford Truck Enthusiasts Forums
Old 04-24-2005, 06:10 PM
codfish codfish is offline
codfish is starting off with a positive reputation.
Question Ticking noise in motor ?????
Hi guys
I have a 1999 f150 with the 5.4 litre engine with 120000 kms on the motor.Yesterday as the wife was leaving home i noticed a tick coming out of the motor as she was leaving.Took the truck for a ride today, the noise seems to disappear as you increase speed or you just can't hear it at increased speeds. Any ideals on what the promblem is and how to solve it would be greatly appreciated.
Thanks
Old 04-24-2005, 06:20 PM
Patatoe1's Avatar
Patatoe1 Patatoe1 is offline
Patatoe1 is starting off with a positive reputation.
If this is a problem, well, I think I have the same one. I notice a ticking when I'm in third gear. Once it switches into fourth though I don't hear the ticking anymore. Please help the both of us.
Old 04-25-2005, 07:58 AM
primetime24 primetime24 is offline
primetime24 is starting off with a positive reputation.
I seem to have the same problem on my 1998 but only notice it when idling. It is really noticeable when i am in a drive thru with a wall on the drivers side. I'm clueless to what the problem is, so anyone got any ideas?
Old 04-25-2005, 08:05 AM
86moneypit 86moneypit is offline
86moneypit is starting off with a positive reputation.
I have the same thing at an idle it has a slight clicking, I have come to believe that it is the fan clutch bearings getting old, on a 2000 5.4 w/67400 miles on it
Old 04-25-2005, 08:07 AM
mel2000f150 mel2000f150 is offline
mel2000f150 is starting off with a positive reputation.
Check the pass. side exhaust manifold, the rear bolts. Mine broke and the dealer said this was common for my year (2000). Mel
Old 04-25-2005, 08:13 AM
Thats interesting, and you never got an exhaust smell in the cab from the poor seal.
Old 04-25-2005, 08:47 AM
No smell in cab.
Also the manifold was warped. The dealer said its like the chicken and the egg, did the manifold warp and break the bolt or did the bolt break and warp the manifold.
Old 05-16-2005, 09:32 PM
budfans budfans is offline
budfans is starting off with a positive reputation.
97 150 4.6 120000 miles on it when mine started ! sounded like a rod but it was'nt inside of the cat came apart and a small piece was tapping around in the pipe . it finally flew out ! no more sound
Old 05-18-2005, 08:44 PM
Bliath Bliath is offline
Bliath is starting off with a positive reputation.
I got a ticking noise too, could be an exhaust leak.
Old 06-18-2005, 05:59 AM
justdave justdave is offline
justdave is starting off with a positive reputation.
I have the same noise at idle, I noticed it at a drive through. I have a 03 F150 5.4 it has 15,000 on it. I opened the hood and used a sounding stick. It seems to be a couple of noisey injectors. I took it to Ford and they said this is normal. I am going to keep a ear on it though.
Old 06-18-2005, 08:30 PM
automaticj5 automaticj5 is offline
automaticj5 is starting off with a positive reputation.
try a higher octane, or a fuel cleaner...
Old 06-19-2005, 10:35 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome justdave, to Ford Truck Enthusiasts!
Please read this.. http://www.ford-trucks.com/forums/sh...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. .
Old 06-22-2005, 10:39 PM
fordtruckfan90's Avatar
fordtruckfan90 fordtruckfan90 is offline
fordtruckfan90 is starting off with a positive reputation.
Quote:
sounds like my problem i have a 99 f-150 4.6 with 43k, its on the pass side motor, exhaust man took a stethascope to the manifolds, and could hear a tick, but a metal tick, not like an exhaust leak, so i was under the hood and i toucked the injectors and could feel the ticking, and yes when between a wall or buildings, you can definately hear it.
Old 06-23-2005, 10:43 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
ford is having valve guide problems with there heads.if you stick your head in the fender well or underneith the truck near the cats and hear it its more than likely worn guides.ford has updated heads that fix the problem.
Old 06-23-2005, 12:06 PM
Quote:
they gonna fix it for free??
My 2004 FX4 5.4 has the infamous tick noise :'( Hoosiergirl 2004 - 2008 F150 11 09-20-2016 11:47 AM
"typewriter" noise showed up at 36k djjoshuad 6.7L Power Stroke Diesel 25 01-25-2015 12:30 AM
2007 5.4 3v ticking ingerson 2004 - 2008 F150 3 07-27-2014 07:47 PM
clicking noise but not at idle gsibert 1987 - 1996 F150 & Larger F-Series Trucks 5 12-21-2013 11:17 PM
ticking that doesn't increase with rpms deserttruck Modular V8 (4.6L, 5.4L) 6 12-30-2004 04:36 PM
Tags
1990, 1997, 2003, edge, engine, f150, f350, ford, hear, motor, noise, sound, ticking, troubleshooting, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
