What is a "scorched" piston? - Ford Truck Enthusiasts Forums
Old 04-24-2005, 01:01 PM
jesta302's Avatar
jesta302 jesta302 is offline
jesta302 is starting off with a positive reputation.
Red face What is a "scorched" piston?
I've been reluctant to post on my new motor, but Houston we have a problem:
It seems that the #1 injector I installed (Accel 21lb) never worked at all. I thought the miss was cam lope..... Well I replaced the bad injector (Accel made good on waranty), and now there is a "tick" coming from #1 AFTER the motor is good and warmed up. It starts out perfect, then slowly appears.
My mechanic concluded that the problem is definitely in the bottom end (Shorted out plug, tick sound changes). He says the piston is "scorched", and clearly this is not good. Motor has less than 1500 miles on it. Also, after 500 miles, I put in 100% synthetic Mobil oil. After reading about the potential problems with putting synthetic oil in newer motors, I have went back to 20-50, hoping the tick would just go away. Well, it hasn't. Have had the valve train went through, and all is in order. Can a bad injector cause a piston to overheat? I figure it just goes up and down, taking a free ride.
Any thoughts or experience with this sort of problem would be appreciated. Guess I'm preparing myself for the worst.
Old 04-24-2005, 11:26 PM
Haaser Haaser is offline
Haaser is starting off with a positive reputation.
Thumbs down It's very possible.
Hello
A bad injector can definetly cause a piston to overheat from it being way to lean. But you never mentioned a knock so the piston might be ok. In a worse case scenerio the rings will break and melt. Boom there goes your engine. But I doubt this happened.
Old 04-25-2005, 06:01 AM
jesta302's Avatar
10-4
Bottom line is the head and oil pan are going to have to come off and have a look?
Old 04-25-2005, 10:36 PM
Unhappy Maybe
Hello
I personly think it would be wise to take the head off and take a look. But if it runs fine maybe you dont need to. But it still would be wise. This to me sound more like a vavle train problem though but you said it was fine. Burnt valve maybe? It's odd that it only ticks while it is warm though or warming up.
Old 04-26-2005, 05:36 PM
jesta302's Avatar
Haaser,
Thanks for the input. A pic of my motor is in the gallery under 95' Bronco section :http://www.ford-trucks.com/user_gall...&albumid=12557 Specs are included. This is a potent motor. I started mine about the same time that the "went to see the engine builder" thread started. I went the crate route, but left off the fuel injection and intake. (15hp for an additional 2 grand was not worth it.) I may live to regret that decision.
7.3 IDI engine knock (bad injectors???) bozone802 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 03-21-2016 01:13 PM
So what exactly does a bad injector sound like? lawdawg79 1999 - 2003 7.3L Power Stroke Diesel 13 09-15-2015 04:55 AM
trying to start after head removal :( Fuzzydog 1994.5 - 1997 7.3L Power Stroke Diesel 75 10-31-2011 09:20 PM
Smoking rear brake - caliper frozen dogerbrown1 1999 to 2016 Super Duty 1 10-23-2011 11:31 PM
TICKING NOISE maybe a Lifter Prototype 305 6.0L Power Stroke Diesel 6 09-30-2009 09:35 PM
Tags
450, boat, diesel, engine, hasser, motor, motos, piston, pistons, raider, scorched, scortch, scortched, torched, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
