Flasher Relay - Ford Truck Enthusiasts Forums
Flasher Relay
Old 04-24-2005, 12:36 PM
racefan66 racefan66 is offline
racefan66 is starting off with a positive reputation.
Flasher Relay
Can anybody tell me where the flasher relay is on my 1998 Ford F-150 ?
Old 04-24-2005, 03:49 PM
jcstratt jcstratt is offline
jcstratt is starting off with a positive reputation.
It's under the dash about where your right knee would be. It is in a socket with another relay.
Ford could have tried to make it more difficult to get out, but then they would have had to mount it to the back of the intake manifold under the PCV port.
Old 04-24-2005, 03:53 PM
Thanks for the information I found it alittle while ago. That wasn't what was wrong my blinkers still do not work.
Old 04-24-2005, 04:10 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
Check under the hood on the driverside there are a couple of fuse blocks there, and look for one about the size of a cigerette pack top 1"x 3" it could be where your problem is, Do you have trailor tow option?
Old 04-24-2005, 04:24 PM
Yes I have a trailer tow option I have checked all of the fuses and I have changed the flasher also, I'm not sure what I should check next. Thanks for the information.
Old 04-24-2005, 04:27 PM
F2504x4's Avatar
You have brake light right? but no turn, do your emergancy flashers work?
Old 04-24-2005, 04:34 PM
I just checked I do not have rear brakr lights,but the light above the rear window works.
Old 04-24-2005, 04:40 PM
F2504x4's Avatar
Okay you do have a fuse blown , look under the hood for that small fuse block , not the one with all the relays and big fuses, this one may still have black cloth tape on it with 4 to 6 tiny fuses in it, the box is only 1 inch by 2 1/2, 3 inches long , kinda easy to over-look.
Old 04-24-2005, 04:48 PM
I'm going to go and check the relays in that box. I do not have emergency flashers or turn signals and rear brake lights.
Old 04-24-2005, 05:48 PM
I do not understand, I now have emergency flashers and the drivers side brake light, but I have not found anything wrong.
Old 04-24-2005, 07:24 PM
I don't think it effects brake lights, but....try tilting your sterring wheel up and down while checking the blinkers. If you don't have a tilt wheel....then nevermind that.
Old 04-24-2005, 08:12 PM
jcstratt, I did what you said and the blinkers work I drive with the steering wheel all the way down when I moved it up the blinkers started working, what do you think it is? Maybe a pinched wire or just a dirty mechanism where the blinker lever is. Thanks for your help.
Old 04-24-2005, 08:24 PM
F2504x4's Avatar
Quote:
Good call!
What I would do is to remove the plastic collar from the steering wheel and and start checking for a loose or broken wires, if its not there then its going to be in the steering column itself, theres a name for the part but I can't think of it right now. Let me do a search and see if I can locate a thread on it.
Old 04-24-2005, 08:43 PM
F2504x4's Avatar
http://www.ford-trucks.com/forums/sh...t=Turn+signals
Most of the other post that I have read seem to indicate that it is a loose connecter in the column, you can check this for yourself be removing the collar from the steering wheel {3 torx screw if i remember right }and wiggle the wires at the connector. lets us know
Old 04-24-2005, 08:50 PM
The problem is usually one of two things. You have to remove the column covers and look at the top back side of the multifunction switch (turn signal switch). Either the plug has worked loose or (like what happened to mine) the pin retainers inside the connector broke and the wires pulled out. You can replace the connector if need be for $35-$42 or you can epoxy them back in place. Epoxy is easy to do and cheap, but you must take care that you do it right and not get it all up in the contacts themselves.
06 E350 flasher enil01 Electrical Systems/Wiring 2 01-04-2015 06:12 PM
no brake lights or rear flashers. franklee86 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 06-17-2012 09:23 AM
2008 Explorer signal flasher karichjr Explorer, Sport Trac, Mountaineer & Aviator 5 09-26-2011 06:40 AM
electronic flasher travisp_95 1999 - 2003 7.3L Power Stroke Diesel 21 01-30-2010 06:26 PM
turn signal flasher 2000 F-150 XL ohheflies 1997 - 2003 F150 1 02-16-2004 08:41 AM
Tags
04, 2003, effect, f150, flasher, ford, location, module, panel, relay, relays, remove, trailer, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
