Anyone else have A/C problem?
Mine works perfectly, but if you do a search on cold, you will find that a number of these suckers were shipped with low charges.
37 at the vent closest to evap, with the system on max, is actually pretty good. It get's much colder, and it will start to freeze at the lines. 36 was optimum in the old systems.
Of course if it's 40 degrees out, how does he check it? That output temp is at a Nominal 76 degree air temp.
Chris
Chris
I had my 04 f150 in last week for poor ac performance. They claim there was some "gunk" in the system so they evacuated and recharged the system. Now with temps in the mid 70's the ac blows ~40 degree air according to the themometer I stuck in the air vent. This is on regular ac with the fan on 2 or so.
When I was working in A/C (short time, back in the dark ages, around 1988-89) the standard test was always with a 'candy' thermometer (or thermal coupling) stuffed into the vent closest to the evaporator, A/C on Max (recirculation) with doors and windows open, maximum blower, and the engine no higher than operating temp. You cool the radiator with a hose if she starts to warm up while you are working.
Anyway, the temps should be below 38, above 34. That's F not C, of course.
In real life the system is a little colder if you keep the blower down, but tell that to your sweaty passengers. The high blower makes them feel cooler.
Chris
Chris
I've read a few threads in the past week where the A/C was only cooling 20-30 degrees below ambient temperature. One thread reported having O-rings replaced and the system recharged.. I also read the thread where a service tech said that some were coming from the plants with only a partial charge.
Hope that does the trick for you..
Russ
Russ
Air conditioner problem
I had the air conditioner problem as well. There is a Techincal Service Bulletin for this problem. It is a simple software update and the replacement of a nozzle that will correct the problem. The whole process takes about 30 minutes. The air conditioner works great now.
