Blower motor clogged (2000 Explorer)
Old 04-26-2010, 03:50 AM
srercrcr's Avatar
srercrcr
srercrcr is offline
Some years back a bunch of tissue was in the A/C blower squirrel cage fan, which reduced the volume of air and made it sound muffled. I clean it and all went well. I figure a tissue might have gotten sucked up into the access behind the glove box. Well, this time it's steel wool and insulation type stuff. I figure a squirrel got in there somehow. Rather than pulling the blower motor out a little to clean the cage (a time consuming endeavor), I cut the plastic grate out behind the glove box, which prevented me access but not the sguirrel. Once removed I could stick a vacuum attachment all the way in there and is a quick fix, all is well. Maybe somebody will benefit from this.
Old 04-26-2010, 06:38 AM
shorod's Avatar
shorod
shorod is offline
Thanks for the tip. I hope you find your mouse.
-Rod
Orange91coupe
11-16-2016 12:43 PM
Bingen08
01-27-2016 07:36 PM
Clem's Cousin
12-20-2014 05:59 AM
m350
11-11-2013 08:22 PM
howlincold
12-16-2008 09:48 PM
Quick Reply: Blower motor clogged (2000 Explorer)
