Sliding glass - rear window replacement - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 04-23-2005, 11:33 PM
Vegas Van Vegas Van is offline
Vegas Van is starting off with a positive reputation.
Our shorty was broken into a few nights ago. Among other things the driver side rear sliding window was broken. Is there a way to replace just the broken sliding window without removing the window unit from the body like the shop manual shows? I can get the parts from a bone yard and would like the quick install.
Old 04-24-2005, 01:44 PM
aerovan aerovan is offline
aerovan is starting off with a positive reputation.
our's was broken into in the same window as yours awhile back. i've tried to just replace the glass portion... but there's just noway of getting the glass out. i've tried to disassemble the unit, but it only got me so far. from what i have tried, its pretty much replace the entire window unit.
Old 04-25-2005, 09:28 AM
maxwgn maxwgn is offline
maxwgn is starting off with a positive reputation.
Yeah, you'll need to replace the entire assembly...I had to do it for BOTH of the passenger side rear windows on our previous van - the 90 shorty...was a little time consuming, but not difficult...hardest part is removing the interior trim, without tearing it up...the window is amazingly easy to do, and also EXTREMELY light weight...you'd be surprised...
Old 04-25-2005, 01:04 PM
spudster spudster is offline
spudster is starting off with a positive reputation.
I replaced the whole assembly on mine about a year ago, got the whole assembly at wreckers for $30 can. I didn't remove the whole interior but just enough screws to be able to get at the 8 or 10 screws holding the assembly.
It took approx 45 minutes to complete.
Rear sliding window channel gtanns 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 04-29-2015 06:59 PM
1995 Ford F-150, 5.0L, Rear Sliding Window OFLM 1987 - 1996 F150 & Larger F-Series Trucks 8 04-17-2015 07:08 AM
2007 King Ranch power sliding window. One cable broken, can I replace? stv1991 1999 to 2016 Super Duty 4 04-05-2015 08:41 PM
Can I buy just sliding glass part of rear window? (got broken) PPrash 1999 to 2016 Super Duty 15 05-28-2014 02:55 PM
Sliding rear window replacement Stinky7-11 1973 - 1979 F-100 & Larger F-Series Trucks 16 02-26-2012 01:14 AM
Tags
2005, 91, broken, f250, f350, ford, glass, rear, removal, replacement, sliden, slider, sliding, truck, trucks, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
