No horn or cruise control
Depending on what year your truck is (I am only familiar with my 90)- there are brushes behind the steering wheel that contact with areas on the back of the steering wheel to give you the connection for the horn, cruise control. As always, begin by looking for simple stuff like a fuse, but if they cruise and horn ceased working at the same time, I'd bet it's a brush or some contact point in the column (assuming your truck has the cruise control on the wheel). I recently installed a new (to me) steering wheel in my 90 to replace the worn out one I had, and the contacts on the back of the wheel were corroded so that I had no cruise or horn.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.excite.com/f100
Nate
1990 F-150 5.8L
>I seem to have lost my
>horn and cruise control. Ive
>checked all my fuses and
>relays but still no luck.The
>only thing I can think
>of is it might be
>in the steering column. Anyone
>have any ideas.
My 1996 E150 had the same thing. There is a Horn Relay under the hood (mine was next to the brake master cylinder. Mine had come loose from the mounting and was hanging upside down, happened to fill with water and corrode. For some reason, the cruise control goes through this relay also. Relay was only available at a Ford Dealer (nobody else had them in stock) for about 5.00.
Regards, Gerry
>of is it might be
>have any ideas.
Regards, Gerry
Thanks all for your replys. Im sorry, forgot to mention my truck is a 94 f-150 and cruise is on the steering wheel. Also my airbag light is flashing but I thought everything was still working untill the other day when i tried to use cruise and horn. Maybe they are all connected to the problem.
CJay
CJay
mauzer1, I will have to show my ignorance about the newer Ford's. I've never had anthing newer than a 90 in the F series or full size Bronco's. What is the clockspring you mention?
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Superdave
No Horn No Cruise
I have a 1990 Econoline F350. my horn has been working on and off and stopped working today. The relay sounds as if it is sticking. It is located on a plastic connection box (2in x 3in) at the bottom right of the steering column.
The relay is welded to a flat bracket that is attached to this black plastic connection box. I disconnected the relay and called the number into a ford agency and they no longer carry the relay. Their computer says the relay is for the cruise control, but the horn uses it also.
I don't know if the 1990 has the clock spring mentioned in other forum responses. Don't know if this helps any. I'm gonna try to replace this relay.
Rose Clifford
35
01-31-2018 02:30 PM
Mikey Cash
08-02-2013 08:40 PM
keyul
Electrical Systems/Wiring
02-17-2005 07:28 AM
