tell tale signs of a bad cps - Ford Truck Enthusiasts Forums
Old 04-22-2005, 05:27 PM
Budkole's Avatar
Budkole Budkole is offline
Budkole is new and has a neutral reputation at this point.
Just wondering what are some of the symtoms of a bad cps.
Old 04-22-2005, 05:38 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
Diagnosis: A bad cam position sensor is usually signified by the PowerStroke motor abruptly and unexpectedly quitting. The motor may also be suffering from slight power loss and slight increase in fuel usage which is usually not noticeable until it is seen as an improvement when the sensor is replaced. When the CPS causes the motor to shut down, the tachometer will not register. If the motor fails to restart, the tachometer will not register when the starter is turning the motor over. This may or may not cause the check engine light to come on.
Part Numbers: The International parts are usually half the price of Ford's, and I wouldn't buy one from Ford unless you absolutely had to.
International part numbers:
A change occurred mid way through 1997, so if you have a 97 it is best to look at the engine serial number. For serial number before serial number 375549 use PN# 1821720C98. For serial number 375549 (including this number) and after use PN# 1825899C93.
Ford Part Numbers:
For 1996 and older use PN# F6T012K073A For 1997 and newer use PN# F7T012K073A
Remove/Replace: CPS replacement is a very simple process. It is located at the 10 o'clock position of the crankshaft pulley and secured with one 10 mm bolt. Removing the serpentine belt will facilitate the removal.
Step 1) Make sure key is off and disconnect battery or pull #9 fuse. This is always a good idea when working on engine electronics.
Step 2) Remove engine belt
Step 3) Unplug wiring plug from sensor by prying out on the little plastic tab and pushing it out of it's socket
Step 4) Use 10 mm socket with small extension to remove 10 mm bolt
Step 5) Clean any dirt or grease off of sensor and surrounding area to prevent contamination of crankcase oil and seal of new sensor
Step 6) Use pliers, pry bar, or whatever else to gently remove sensor by pulling it straight out. It may be slightly stuck and slight force may be needed to loosen it. It is ok to twist it in its socket to loosen it if necessary.
Step 7) Coat new sensor o-ring with clean engine oil and press sensor into hole.
Step 8) Replace 10 mm bolt, torque to 10 ft-lbs, or just make sure it is snug.
Step 9) Replace wiring plug by simply pressing it into position until you hear the holding tab click into place.
Step 10) Replace belt.
Step 11) Ensure battery has been disconnected or #9 fuse has been out for at least 30 minutes. After this amount of time, they can be replaced.
Step 12) Start engine and inspect for leaks or other problems. Make sure belt has been properly aligned on each of the pulleys.
Old 04-22-2005, 05:46 PM
Budkole's Avatar
Thanks a bunch, Today i was on the highway and the check engine light came on and all the power was lost until i put my foot on the gas. After i put my foot on the gas, everything went back to normal and i made it home. But now, i am scared to drive it anywhere 1995 f350 cc dually 2x4
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
When my would act up it would act like the ignition was turned off then on real quick while operating at a steady speed. It was usually so quick you could tell something happened but couldn't tell what. It would also stall either while at idle or when coming to a stop. When the engine stalled it would always restart. Eventually it set a code for intermittent cam sensor signal.
Old 07-27-2013, 12:21 PM
mcachran mcachran is offline
mcachran is starting off with a positive reputation.
CPS?
My 2001 F250 7.3 cut off in the middle of the interstate in bumper to bumper traffic yesterday. Thought it was the CPS or fuel filter, but replaced the CPS and the fuel filter looked okay (although I didn't have one so I haven't replaced it yet). It was running rough and it will start occasionally and run really rough before cutting off. No check engine light. It's like it isn't getting any fuel, but other than that all the symptoms are similar to a CPS problem. Not sure if I have a bad CPS (even though it's new) or if it's something else. One thing I did not do was disconnect the battery for 30 minutes (it was only disconnected for 5 minutes tops). Any ideas or help?
Old 07-27-2013, 04:11 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Quote:
Your 01 will have an electric fuel pump, turn the key to the run position, and check the fuel pressure at the schrader valve on the fuel filter. You can check it with a cheap pencil type tire pressure tester. I think you should have 40 lbs or better. If you don't have something around this pressure, you will know it is something in the fuel system, ie the pump, restriction in fuel line, power to fuel pump ect. You might get more answers if you posted in the Superduty 7.3 section.
Old 07-27-2013, 04:53 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
Quote:
the 99 and up powerstrokes do not have a schrader valve on the fuel filter unless you install it.
Old 07-27-2013, 09:37 PM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
Well, the first help would be to start a new thread, and then the help after that will be more than you could ask for. There are some good, knowledgeable guys on here.
Old 07-27-2013, 11:12 PM
Quote:
My mistake, thanks for the correction.
Old 06-30-2015, 11:21 PM
Farmerjon19 Farmerjon19 is offline
Farmerjon19 is starting off with a positive reputation.
New for me
When under heavy load at higher rpm (whipping out in traffic)at 2950rpm it would die and roll white smoke took out the cheap bed cps sensor and put an international one in all is well just weird cause no stuffer at idle no other symptoms just at certain rpm just thought I'd share
Quote:
Old 07-06-2015, 06:24 PM
bass-n-fire's Avatar
bass-n-fire bass-n-fire is offline
bass-n-fire is starting off with a positive reputation.
So what happens if you do not leave everything disconnected for the allotted time?
Old 03-08-2016, 04:25 AM
Philliamwallace Philliamwallace is offline
Philliamwallace is starting off with a positive reputation.
How do you reset the fuel Guage?
How to reset fuel guage?
Old 03-08-2016, 07:39 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Put fuel in it and the needle goes back to F....reset complete. Lol
Have no idea what you are asking.
7th cps in a row bubba_3711 1994.5 - 1997 7.3L Power Stroke Diesel 12 03-20-2016 03:17 PM
Blue CPS Problems?? duggyb 1994.5 - 1997 7.3L Power Stroke Diesel 15 03-08-2016 08:45 AM
The 3 CPS's - revisited Hussler 1994.5 - 1997 7.3L Power Stroke Diesel 12 09-19-2015 04:54 PM
CPS Whitey Ford 1994.5 - 1997 7.3L Power Stroke Diesel 16 03-05-2015 01:33 PM
CPS failure willbd 1994.5 - 1997 7.3L Power Stroke Diesel 8 12-24-2005 12:10 PM
Tags
19945, 73l, 99, bad, cam, codes, colorado, cps, diagnosis, f6t012k073a, ford, powerstroke, removal, sensor, symptoms, tach
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
