2005 F350 Bed to Frame Bolts - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-22-2005, 02:41 PM
xpropilot xpropilot is offline
xpropilot is starting off with a positive reputation.
Hi Y'all,
Re. the T-45 bolts that bolt the truck bed to the frame: Can someone please tell me how many lb.ft. of torque that those bolts are supposed to be tightened to? They were removed to to a spray-in bedliner and I found a couple loose.
Thanks,
Bruce
Old 04-22-2005, 08:00 PM
vrsc's Avatar
vrsc vrsc is offline
vrsc is starting off with a positive reputation.
Me as well, found some loose.
Old 04-24-2005, 05:29 PM
bgrover bgrover is offline
bgrover is starting off with a positive reputation.
<TABLE width="95%"><TBODY><TR><TD>Here you go,
SECTION 501-04: Pickup Bed and Platform Body
</TD><TD align=right>2005 F-Super Duty Workshop Manual
</TD></TR><TR><TD>SPECIFICATIONS
</TD><TD align=right>Procedure revision date: 07/02/2004
</TD></TR></TBODY></TABLE>
<HR><META content=SPECIFICATIONS name=tps_proctitle>
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>Torque Specifications </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description </TH><TH vAlign=bottom align=middle>Nm </TH><TH vAlign=bottom align=middle>lb-ft </TH></TR><TR><TD vAlign=top align=left>Pickup Box Bolts </TD><TD vAlign=top align=middle>63 </TD><TD vAlign=top align=middle>47 </TD></TR><TR><TD vAlign=top align=left>Dual Rear Fender-to-Fender Bolt(s) </TD><TD vAlign=top align=middle>25 </TD><TD vAlign=top align=middle>19 </TD></TR><TR><TD vAlign=top align=left>Dual Rear Fender-to-Fender Nuts </TD><TD vAlign=top align=middle>25 </TD><TD vAlign=top align=middle>19 </TD></TR></TBODY></TABLE>
Old 04-25-2005, 06:51 PM
Thumbs up
Thanks for the info.
Bruce
64 to66 cab and bed 66feee 1961 - 1966 F-100 & Larger F-Series Trucks 5 11-26-2014 03:13 PM
bed mounting Faber 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-12-2014 12:25 PM
Bed Bolts SCD 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 07-05-2011 05:57 PM
how to remove truck bed?? DJdemon6696 1987 - 1996 F150 & Larger F-Series Trucks 2 12-08-2009 04:46 PM
Pickup bed crossmember installation Delzell 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-24-2005 07:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
