ID'ing ratio of 1st gear in a T19 transmission - Ford Truck Enthusiasts Forums
Old 04-22-2005, 12:06 PM
superbepro superbepro is offline
superbepro is starting off with a positive reputation.
Question ID'ing ratio of 1st gear in a T19 transmission
I bought a T19 transmission yesterday at a local junkyard ($150). It came from an '84 F250 with a 460 gas engine (with ?27,513 miles). I want to know if there is away to find out what is the ratio for the first gear (4.02, 5.11 or 6.32). I really want to get a close ratio T19 (with a 4.02 first gear). Some of the transmission case markings read T19-148, 13-09-065-911 Borg Warner. The door sticker lists a code Trans=P. Thanks for any help figuring out what I have before I spend money fixing some minor details and maybe even refreshing it with new synchros and gaskets and such.
By the way, the darn transmission almost gave me a hernia. I had to get the help of another guy to put in my truck's bed (even between the two we puffed). I figure it easily weighs way over 150 pounds (even with the bellhousing off!). Thanks.
Raul
Old 05-28-2013, 08:51 PM
SgtEnnen SgtEnnen is offline
SgtEnnen is starting off with a positive reputation.
Best way to figure it out would be to put it in first gear mark input and output. Turn the input and count how many times you have to turn it to get one full rotation from the output. Just know if you have to turn it over 4 turns but less then 5 then you have the one you want.
Old 05-28-2013, 11:39 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
Eight (8) years ago......
Odd overheating issue. Please help. Thanks in advance. BleedFordBlue_Al 1997 - 2003 F150 5 03-06-2016 09:33 PM
BATTERY MAINTENANCE ? What you say! Thomas White 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2015 01:25 PM
Trouble Shooting Challenge - Logic Help Appreciated! Grinder Man 1997-2006 Expedition & Navigator 14 10-10-2014 09:35 AM
Custom Gauges PA F250 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-28-2013 06:35 AM
Front coil springs....lb ratings PhilfromFlorida 1999 to 2016 Super Duty 30 04-02-2008 03:50 PM
Tags
1309065911, 19, 511, borg, case, code, f150, ford, id, t19, t19148, trans, transmission, truck, warner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
