Put a Ford in your Ford - Ford Truck Enthusiasts Forums
S. California Chapter Join Chapter, Leader: wpnaes
Old 04-22-2005, 11:28 AM
edsf100's Avatar
edsf100 edsf100 is offline
edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.
Send me an email for tickets, buck a ticket.
Western Nationals June 25th - Grand Prize Drawing - 5.8L/351 crate motor.
Winner not be present - Ford will drop ship to your house.
8.5:1 compression ratio
Ford racing dual plane 4V aluminum intake, Ford Racing tall polished aluminum valve covers, V-belt standard rotation mid 70's style cast iron water pump with left hand inlet, aluminum timing chain cover with fuel pump mount, fuel pump block off and eccentric, E5AE-6090-CA cylinder heads without thermactor air passages, F4TR-6380-AA HD truck manual trans flywheel, high torque flat tappet cam E7JE-6250-AA, full sump oil pan, Duraspark distributor and coil, spark plug wires, block is hydraulic roller cam compatible.
<!-- / message --><!-- sig -->
Old 04-24-2005, 04:23 AM
low springs low springs is offline
low springs is starting off with a positive reputation.
do you have pay pal or do you prefer MO?
Old 04-24-2005, 02:20 PM
edsf100's Avatar
Pay Pal or MO which ever you like. I will need you name and Ph# via email for the tickets.
ASKING PRICE FOR MY 428 FE ? 427HISS FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 02-21-2010 10:57 AM
Bore and stroke... 77_F150_4x4 Performance & General Engine Building 10 11-19-2007 11:58 PM
Ford in your Ford edsf100 1961 - 1966 F-100 & Larger F-Series Trucks 18 06-14-2005 07:14 PM
Ford in your Ford edsf100 1967 - 1972 F-100 & Larger F-Series Trucks 13 06-06-2005 09:19 PM
Ford in your Ford edsf100 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-17-2005 10:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
