Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-22-2005, 07:03 AM
biglee biglee is offline
biglee is starting off with a positive reputation.
1945 1/2 ton ford p/u >>Brake pedal assembly<< ???
Hi All,
Still working on my 45 p/u.
Can't beleive how long it takes to build one of these pickups.
And the money involved . Whew!!!
Anyway, I am about ready to set up my brake system and I need to know what vehicle to use to find my BRAKE PEDAL ASSY.
I will have GM 4 wheel disc brakes.
Would a GMC G20 full size van work good on this application or do I need to go with like a full size chevy pickup truck ?
I know most of you have done something in this order.
Please let me know what to use,IE (what vehicle to rob from a bone yard).
I used a 1991 GMC G20 full size van steering column,and it is a perfect fit for the length,and it came with 2 swivels at the bottom. I have to rebuild a mount to bolt it to under the dash yet,but this is normal for refabing these ole trucks.
I used a 1979 camaro front stub on the front and a 1980 t/a 10 bolt rear axle w/disc brakes.
Thanks all,
Lee
  #2 (permalink)
Old 04-29-2005, 10:57 PM
alittle40 alittle40 is offline
alittle40 is starting off with a positive reputation.
If you want to keep the firewall clean, go with a Kugel style. It turns the master cyliinder 90 degrees to the pedal, 70's Dodge vans had them. If you are looking for a compact unit try a 76 - 80 Ford LTD ll . It has a 9 inch booster and large capacity master cylinder with proportioning valve. Go to Master power brakes website to get some good brake information.
__________________
C U AL
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
